Question about Philips MMS 203 Computer Speakers
NO SOUND COMING OUT .I HAD IT FOR SOME TIME AND SEE NO SIGN OF PROBLEM TURN IT ON IN THE MORNING WENT TO WORK LEFT IT ON WHEN GOT BACK NO SOUND COMING OUT i really like this speaker
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Low humming noise and burnt plastic smell coming from 1990 acura integra
Jennifer what type of timing belt does your engine use ?
Is it Nylon ? When was the last time you had it changed ?
Burning plastic smell may be being caused by the timing belt bearing runners seizing and the belt is getting hot .
If the belt is due to snap you could cause a lot of damage to the engine if it breaks.
Might be worth getting a mechanics advice on this as a possible cause
Mar 04, 2017 | 1990 Acura Integra
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
I have shut down my computer that was working just fine until the next morning. When I turned it on again the computer turned on but everything connected to it (monitorkeyboardmouse etc.) won't come on....
Unplug everything not needed ( printers / copiers / usb devices and drives.
Check CD/DVD/floppy drive for discs, remove them.
Try using different power extension leads / check fuses.
If your monitor / mouse (if its optical) are also dead and dont show any sign of life, it sound like a problem with you power leads/adapters
Jul 18, 2010 | Computers & Internet
I got a Civic '02 the drl sign lights up and loud noise is coming from the glove compartment area. After investigation I found out the right light is not on while the left is fine (when the drl sign shows...
The DRL stands for daytime running lights. There is an electronic module that controls the operation of this that is located under the dash, which is probably where your noise is coming from. The noise goes away when you turn your headlights on because the DRL will disengage. I have replaced these before on civics and it should cure your problem. When ordering your part ask for a "daytime running light module". Hope this helps.
Jun 15, 2010 | 2002 Honda Civic
Not working
Did you try to physically unplug the TV? Leave it unplugged for a few minutes then plug it back in.
Apr 03, 2010 | Hitachi 51S500 51" Rear Projection...
Nokia 6500: Dodgy screen?
simply check the connections of the lcd to the board... or just tighten the screws... i had repaired a phone of that problem and this was my solutions.
May 31, 2009 | Nokia 6500 Slide Cellular Phone
TV will not come on.
check to see if the power cord is pluged in firmly
Dec 17, 2008 | Sylvania 6427GFG 27" TV
HS2 doesn't turn on
try holding the power on/off button for about 15 sec to power off completely, then push the DVD button. that may work.
Nov 12, 2007 | Panasonic DMR-HS2 DVD Recorder
Philips MMS 203 Computer Speakers Logo
22 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
