Question about Intermatic Hardware & Accessories
I have lost plastic pin{red} for my indoor light timer. Is there anything I can use to replace it,or can I buy a new one? If so where can I get them? It is an INTERMATIC TIME ALL Model No. TN111.
Open following link for Intermatic trippers and parts with identifying numbers and ordering information.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
According to Intermatic information, TN series uses 107TN222 turquoise ON tripper, 107TN221 red OFF tripper.
Order from Intermatic:
http://store.nexternal.com/intermatic/categories.aspx?Keyword=107TN221+tripper&x=20&y=13
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Posted on Apr 03, 2011
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Looking to buy the red pin to set the sign timer
1) Timer is not identified.
Question posted under Intermatic T100 series which has metal trippers, and not green and red.
2) Copy following links to help identify timer:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Tork-timers-and-manuals.html
http://waterheatertimer.org/Paragon-timers-and-manuals.html
3) Add a comment Dec 2012 and describe timer in detail. Or attach a photo of the timer for possible identification.
Dec 10, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
My automatic timer is not working.
You posted under Intermatic raintight timer.
Add a comment with your model and brand and I have extensive files on timers.
The best diagnostic is the manual override.
1) Click manual override and see if Load (lights, fan, motor) come on.
If manual override clicks on-and-off crisp and clean, but the lights do not come on, check your electric power.
If the manual override does not click crisp and clean, then the timer may be rusty, or timer may need to be replaced. Buy replacement timer and swap out timer mechanisms without changing the box.
If the manual override works fine, and Load turns on-and-off with manual override, then the clock or trippers are next suspect.
2) Check if the dial is turning as time passes.
If the dial is not turning, then the clock motor is bad and you can buy a new clock motor.
If dial is turning, and manual override turns Load on-and-off, then the tripper pins might be worn out, and you can buy new trippers.
3) To buy replacement parts: Timer door has model number of timer. Timer clock located on back of timer mechanism has identifying numbers. You can snap out the timer mechanism using metal spring locate top inside box.
Grainger sells trippers and motors:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Aplus sells motors:
http://www.aplussupply.com/intermatic/timermotors.htm
Intermatic sells motors:
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Nov 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Not turning itself on and off. tigger are set clock is running. light are on 24 hours. model no T101 diana or shannon
1) The on-off tripper pins might be worn out. Buy new pins
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Do you need new pins?
2) The manual override will click on and off with timer. Watch if manual lever is moving to OFF when timer is off ... and moving to ON when timer is on.
3) Timer might be worn out. Click manual override lever back and forth.
Is manual override loose? Or does it click crisp ON and OFF? This test would indicate general wear on timer. If manual override is loose or broken, the tripper pins may pass right over without tripping lever.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/images/WH-lever-005-500.jpg
http://waterheatertimer.org/images/Back-of-WH40-2b-500.jpg
4) If manual override clicks on and off with timer, and lights stay on, then there might be a short between timer and lights.
Test for short to ground. Turn off power. Inside timer box, disconnect ground wire going to light. Do not disconnect ground wire unless power is off. Turn power back on. If lights are off, then the wire going to light is bad, or a light fixture is bad.
Caution. If there is a short, do NOT touch light fixture when power is on.
Sep 17, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Hello I have an older T103 Intermatic which controlls outside lights. It is no longer turning on lights and is making an unusual clicking noise. Can it be repaired or should I install a new...
You can replace the clock motor for $16 ...
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
... but if the mechanical timer mechanism is worn out, then that is not repairable. To check mechanism, lift timer dial and rotate tripper pins out of way, then click manual override on-and-off >> if override works fine, and lights come on then motor is probably the problem.
If you buy a new T103, the insides might snap right into old timer box without needing to replace the box. To remove insides, depress retainer spring located at top, tip out timer, and lift to remove. New timer has 4 tripper pins. Save old tripper pins, and tape them inside box.
Sep 09, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
How to set a timer to come on at 8am off at 8pm
you set the arrow to the correct time. You then pull the green and red plastic pointers up and out of the device and push them back in at the times you want it to activate. I believe green is off and red on but I may be backwards on this. Some come with multiple on and off pins you would simply remove these or pull them up so they do not trigger the timer
Oct 29, 2009 | Intermatic 10 Amp Mechanical Indoor Timer
I have an intermatic T101 and the trip pin broke off. Can I replace the tripper or do I have to buy an new unit?
You may be able to rig it up. They dont sell parts for these. If you can jury rig it just get a new one
Sep 12, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic Time All ,model TB111. lost plastic pin
I have the pieces for an Intermatic Time All, model TB111 because mine stopped working. I don't know how to get in touch with you.
Jul 20, 2009 | Intermatic Hardware & Accessories
Hardware & Accessories Logo
287 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
