Question about Logitech LS11 Speaker 2 Speakers
My speake is giveing problem cant leson to nun
  • Logitech Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 03, 2011
0.00105 in sceintific notation show work
0.00105 = 1.05/1000 = 1.05 E-3
And please don't swear here on Fixya, kids are looking.
Sep 30, 2014 | The Learning Company Achieve! Math &...
Habe leider 3 mal den falschen code eingegeben nun soll ich den puk code eingeben. leider weis ich es nicht mehr. was mache ich jetzt?
sir please call to the related simcard customercare and say the last 6-digit number which is present before the simcard. then they will give the pukcode number to unlock the cellphone...........
Jan 02, 2011 | Nokia E50 Cellular Phone
Needs compressor. I want to buy fridge, install compressor, and resell. Any tips? I am epa-certified, but short on experience.
leson one then,,,,,dont bother! ,,,but if you can find a second hand compresor from a junk yard that will work and you have the gass to re-fill it up with go for it,,,,if not,,,,,dont bother!
Nov 28, 2010 | Jenn-Air JCD2295HES Side by Side...
There is an intermittant problem with my Quingo Plus, it starts sometimes,sometimes not even with the two new batterys fully charged. can you help please. Tom.
Check your Potentiometer Commonly known as a Pot Its under and Attached to your Levers for forward a Reverse Driving if this unit is Giving trouble you will have to Replace it, Does it Bleep Bleep Bleep.
Gerry.
Aug 10, 2010 | Health & Beauty
Hi i have a bmw1200lt 1999 speedo stoped working and cruise control notb working this started when i jet washed bike can anyone help
well leson one,,,,never put a jet washer on a bike,,,it causes more troubel than its worth,,, bmw's have all ways had a problem with bad joints,,,water gets into the joint and then some thing stops working,,,take the fule tank off and pull apart every jiont in the wiring you can find (one at a time please) clean the jiont with switch cleaner and put in some vasaleen then push the joint back together you will finaly find the one thats giving you this problem,,spray into the switches as well with switch cleaner and work them hard to clean them up,,it wont hert anything,,its made for this job!
Jun 06, 2010 | 2003 BMW K 1200 LT
I fave a microphone in my web camera. And Rosetta Stone detects it. But I can't pass the microphone setup before a leson. I can speak for hours, but Rosetta Stone doesn't stop the checking. However it can...
I solved by going to Control Panel, Sound, Recording, then click on your mic and click on Configure, and then Set up microphone... Thats probably going to fix your problem... That easy... xD
Apr 04, 2010 | Rosetta Stone V3 English (U.K.) Level 3...
Frank,on a mb 1979 300d the engine runs but nun of
Check the center lower pulley harmanic balancer if center of pulley spinning, could be broken and just spinning on outer pulley hub.Hope this was very helpful Good luck
Dec 24, 2009 | 1983 Mercedes-Benz 300-Class
Logitech LS11 Speaker 2 Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
