Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
I have a Rheen power Vent 21VP75E-1P, it ignites burnes for a few seconds it clicks and the gas shuts off. It immediately re-ignites and does the same thing repeatedly. I bypassed the vacuum switch to see if that was the problem but it acted the exact same way.
Before calling service technician, here are links you can review Rheem and gas water heater manuals and information.
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Typical power vent manual has troubleshoot steps that might or might not apply:
http://waterheatertimer.org/pdf/Rheem-ResPowerVent.pdf
Post question on pro water heater forum
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Find age of water heater:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Identify your product:
http://waterheatertimer.org/pdf/Rheem-Gas-models.pdf
Posted on Apr 04, 2011
I have a Rheem power vent hot water heater that goes into lockout
go to waterheaterhub.com and search for your specific model as there are more than 1 power vent unit made. I would start there before anything else.
Sep 08, 2017 | Rheem 43VP50E2 Power Vent Induced Draft...
Rheem gas power vent water heater model# 21vp75e-19 keeps tripping gif breaker when plugged in, help please
Check where wires go into housing, look for a bare or nicked neutral (white) wire. GFCI's only trip when the neutral makes contact with ground.
Mar 08, 2014 | Rheem Water Heaters
Rheem 21VP50-1P - power vent running non-stop.
Rheem does not post service manuals, but other manufacturers do.
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Also, scroll up on same page, on right side for heading title 'Pressure switch' for troubleshooting the pressure switch.
Don't forget to check anode rod to protect steel tank from rusting.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
Oct 12, 2012 | Rheem Water Heaters
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
Sweeting from top of heater
Water on top of gas heater can be caused by poor venting, or inadequate combustion.
Make sure water is not coming up from under tank top, indicating tank leak requiring tank replacement.
Have a plumber look at problem to make sure home is not filling with deadly, odorless CO gas.
Inspect pipes that they are not corroded and covered with condensate.
Check that roof cap is in place.
Let heater fire and burn for a few moments so the fire is going good, and then light match just outside the draft hood on top of heater. Blow out match and see if smoke draws immediately into vent and upward.
http://waterheatertimer.org/Leaking-water-heater.html
Aug 31, 2012 | RTO RHEEN Water Heater Gas Valve - Natural...
Rinai tankless water heater code 12
Thermocouple may need replacement.
Nov 01, 2017 | Rinnai Water Heaters
I have a rheem power vent 21vp75e-1 it ignites the burner for couple of seconds and shuts off and retry to ignite into a lock out I wire jump the vacuum switch and it works properly than i replace the...
Before calling service technician, read manual for troubleshooting and yearly maintenance requirements.
Open following links to identify same-similar product and download manual.
Once you have product showing on page, click 'specs-docs' tab to see use-and-care manual.
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
http://globalimageserver.com/fetchDocument.aspx?id=c0471d58-5e59-4be6-96f7-68361b8fb515
Rheem site loads slow, and some manuals never load.
Typical power vent manual:
http://waterheatertimer.org/pdf/Rheem-power-vent-manual.pdf
I believe the 21VP is older and Rheem does not show older manuals, but manuals are generally generic enough to help greatly. Year of manufacture show as second and third digit of serial number.
Lockout condition requires service technician and part replacement, or call Rheem and have them send part.
I found one link that talks about FV lockout that may or may not pertain to your issue:
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/
Apr 19, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
The flame switch is making a clicking noise and is not igniting the burner on my rheem power vent. the glow light comes on but does not ignite the burner. how can I fix this problem
It sounds like you either have the gas shut off, or you have a bad regulator. Make sure the gas is unrestricted.
Hope this helps
Dec 10, 2010 | Water Heaters
I have a Rheem Power Vent propane water heater model3 21VP4OE-1P that is acting up. The pilot lights and then the burner lights, but goes off after 5 - 10 seconds. It cycles like this 2 or 3 times, then...
check the thermal coupling for the pilot light. if it goes out it will shut down gas supply, its a safety feature to put out pilot light if the thermal coupling is bad. to prevent gas from leaking and causeing a fire. check coupling.
Aug 12, 2010 | Water Heaters
Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
Apr 04, 2009 | Water Heaters
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
840 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
