Question about Hotpoint Aquarius WF000 Front Load Washer
Horrible rumbling from back of drum. I have dissconnected all the pipes and power lead and removed the top. When i spin the drum by hand there is a horrible rumbling from what seems to be the back where the big pully wheel is connected. Are there bearings that wear out? Is it an easy repaire to replace these if there is? i just like an idea before i go out and buy a new one. Many thanks for any help Roy
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
Roy, it sounds like the bearings are completly worn out. Its not an easy repair and if you decide to repair it leave it to the service tech.
to fix this properly a full new back section and shaft is needed which can be pricey but if your machine is under 5 years aprox £100 will fix it through the hotpoint parts warenty.
if over 5years aprox £140 will fix it again through hotpoint.
hope this helps you out
Posted on Apr 03, 2011
Tub not spinning made bad nosies before it stop spinning
if the main drum bearings have failed hence the noise it may have thrown thee drive belt open the door hold the drum top and bottom and try to push the drum up there should be no movement rotate the drum by hand any rumbling noise is so the bearins have failed
Mar 09, 2014 | Samsung WF218ANW 4.0 cu. ft. High...
LG dryer Model DLE3777W Very loud & rumbling, Drying times longer and not spinning as fast
Loud and rumbling usually means that at least one of the drum support rollers is not turning freely. It is a bit of work to replace them.
1. disconnect power to machine. 2. remove top by taking 3 phillips head screws out of back edge of top, then standing in front of machine, use palms of hands to sharply push top back about 2 inches and lift off. 4. remove control panel (you do not have to disconnect wires to it, just lay it on top of machine.) 5. remove screws at 4 and 8 O'clock positions behind door, screws along top edge of front panel, electrical plugs to light and door switch, and by tilting panel forward, the plug near the bottom for the sensor, allowing the front panel to be removed and set aside. 6. remove 2 phillips head screws from each side of drum support, allowing support to be lifted up about a half inch and removed, giving access to the front support rollers. 7. Release belt and remove drum to access rear drum rollers. 8. replace offending rollers and re-assemble.
I've skipped over a few minor steps which should be obvious as you go.
Feb 20, 2011 | LG DLE3777 Electric Dryer
My dryer rumbles when it is spinning. But it also does not spin at times either. There is heat and when the tumbler does spin, the clothes come out very dry, so heating is not a problem. I'm just...
Ok you have a simple solution to repair your dryer if handy with simple tools. First purchase a belt for the drum and a roller for the belt tensioner. Sears will sell this in a kit form at any Sears store. The top of the dryer will have to come off then the front panel. The front section of the top will be needed to pry upward to remove upon when you remove the rear brackets on the back of the dryers top section. After removing the top, unplug all electrical connections. all should be diffenerent in shapes and sizes which is helpful to you.
The front panel may have screws on the sides that have to be removed.
Some models has a small secondary lower panel that simply pushes down and pulls out for removal
Now that the dryers drum is exposed you need to pull the straight drum out.
Now you will see the tensioner with the roller attached. The roiller you have on your will probably has a frozen bearing and a flat spot on the roller that causes the thumping noise when spinning. The belt has been stretched by the roller being uneven so long making the drum to stop when using you dryer.
Install the tensioner and weave the belt in through the tensioner and wrap it around the drums backside with a helper helping you
With some help you can slip it back in and reassemble this dryer.
Apr 10, 2010 | Dryers
Our Hotpoint WF321 1200 spin is just 3 years old and now makes a very loud noise when in use - both for the washing and spin cycles. is the drum loose / off balance? any help appareciated
Remove lower rear cover of washer, remove drive belt, and from the front spin drum by hand, if it feels rough, or is rumbling, or noisy, then the main drum bearings are failing.
This is a major repair!!!.
Mar 13, 2010 | Hotpoint Washing Machines
Washer makes thumping noise when spinning and belt jumps off
I suspect that the main drum bearings have failed.
Remove the belt, and from the front spin drum by hand, if it feels rough or is rumbling or noisy, then drum bearings have failed.
Can be expensive!!!!
Feb 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Spin the drum by hand, it make metal noise
Remove the rear lower panel of washer,and remove the drum belt.
From the front of the washer, spin the drum by hand, and if it feels rough or is rumbling, could be the drum bearings are going.
If there is something caught, it will make a completely different kind of noise, more like a catching or rubbing noise.
If no noise,then could be the motor that is casing the noise.
Hope this helps.
Jan 23, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Aquarius WF540 sounds like bearings gone How do I take the top off to examine?
No need to remove the top.
Just spin the drum by hand from the front.
If it feels rough, or is rumbling, then the main drum bearings have failed.
There should be no noise at all.
Hope this helps.
Jan 15, 2010 | Hotpoint Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
How do i change my tumble dryer belt on a beko thanks
Just changed the belt on a Beko DRCS68W and its a real pig! Remove the top panel and loosen all screws on complete back panel having removed circlip holding the drum spline on to the back panel. You will also need to disconnect wires/leads on top right inside panel to give you more space. Once you have done this you should be able to ease away the back panel far enough to get the new belt around the drum and over the drum spline in the middle. Then the tricky bit - getting the belt tensioned on to the motor drive spline. I did this before securing the drum and back panel, which gives a bit more flexibility. I also used about 15ins of 15mm copper pipe to ease the belt down over the motor spline. Hard part was getting the back panel back lined up with the screw holes as the belt tension distorts the casing. Finally hit on the idea of lying the machine on its side so the weight of the drum is pulling away from the motor and helping to line up the screw holes. Two and a half hours later job done! I guess if I ever did another it would be a whole lot easier but still not the type of job I relish!
Mar 06, 2009 | Dryers
Hotpoint Aquarius WF000 Front Load Washer Logo
99 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
