Question about Ovens
My Westinghouse model OMB-4 will warm but not heat up to a cooking temp any ideas
2 Suggested Answers
SOURCE: gas oven won't heat
You most likely have a defective oven bake ignitor.  Call an experienced tecnician.
Posted on Oct 10, 2007
Hi,The cooker is cooking at a to higher temperature (either stays warm or when you turn up the temperature seems to cook at a very high temp. The fan works and when turn the knob, it clicks as if
The thermostat is working in that it supplies power to the heating element but it is not working in regulating the temperatures in between. Needs to be replaced/adjusted.
Nov 16, 2015 | Ovens
Why does my oven on fan only heats sometimes
you must have the temp set to low, so if you cook a big thing it will get warm, & a small item wont heat it up at all, because the fan air can circulate better, which keeps the temp down.
get the manual & turn it up. if thats not the problem, then the thermostat is on its way out.
Sep 03, 2014 | Neff Ovens
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
I have a Zanussi oven without a manual. It has a rectangular screen with 9 buttons below it. It has numerous symbols for cooking and I have no idea what some of the symbols mean. Can anyone give me a...
I can tell you what the buttons are for but really you may need to get in touch with your local dealer or Electrolux to either get a hard copy or download one from their website.
Starting from the left is your main power button.
Then the oven function button.The next one is the fast heat up/defrost function.Next is the temp. control/current temp.Next the two with + and _ control time or temp.Next is the minute minder.Next is cooking time.
Finally the last one inicates end of cooking time.
May 03, 2010 | Zanussi ZBQ965 Electric Single Oven
I need correct temperature readings
On most US ovens the high temp is 550f and the lowest is around 100f for warm. I would imagine 1 is warm and 5 is 550f so 2 would be 250 3 would be 325 4 would be 425. Or you could say ribs and slow cooking 2, cake 3, cornbread 4, and 5 would be broil. The only way to know is set each number and place an oven thermostat in there to see what the temp is fer each number. Personally my grand mother cooked on a wood stove and never had a knob, she just shoved the biscuits in the oven and added another stick of wood.
Jan 28, 2010 | Ovens
GE 24" Oven
THE TEMP IN THE OVEN IS CONTROLLED BY A THERMOSTAT.IT GOES FAULTY IN TWO WAYS.IT EITHER OVER HEATS OR UNDER HEATS IN YOUR CASE ITS SOUNDS LIKE ITS UNDER HEATIN.BEST YOU GET A TECHNICIAN TO CHECK IT AND CHANGE IT FOR YOU.GOOD LUCK.MOHAMED
Sep 12, 2008 | Ovens
Maytag MER5775QAS
Could be a couple things. If your machine is actually failing either a control board or an oven sensor.
Also measuring the temperature can only be done by a tech unless you have a special tool. Oven thermometers are inaccurate. Plus most ranges should vary temp between 50-75 degrees unless has a feature or the more recent ones keep it between 15-25 degrees.
Try the biscuit test, buy some biscuit, brand not important, i just say pillsbury. Cook exactly as recommended on package. If results are a little overcooked or a bit undercook try a feature called Adjusting the oven temperature or Calibrating the oven. This can be done by following the instructions in your book.
Maytag.com click support click manuals put in model MER5775QA (notice i took off your models S) open the Use guide, page 14
May 01, 2008 | Ovens
Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Nov 17, 2007 | Ovens
Gas oven won't heat
Oct 09, 2007 | Ovens
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
