Need to know where the connectors go on this tv, got it from a friend who couldn't fix it. From the main boards to the light engine
    Scholar:
  • 67 Answers
Send me a make and model and I will get you the service manual
Posted on Apr 03, 2011
LED TV has sound but no picture?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 20, 2016 | Televison & Video
No picture on tv but does have sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
May 11, 2016 | LG 47LN5700 47" 1080p Smart TV 120Hz Dual...
How do I know if I need to replace the main board?
Vizio TV Repair - How to Install Vizio LCD Motherboard ...
? 6:21
https://www.youtube.com/watch?v=B_ae3f7C3jQ
Feb 20, 2012 - Uploaded by Brady Smith
Learn how to replace your LCD Visio TV motherboard and hear a few facts ... ANYBODY KNOW HOW TO FIX OR WHAT NEEDS TO BE FIXED IF THE ... I have found that I need to replace themainboard in my vizio 42 inch. .... hey, man. can you help me out? i got a VIZIO E3D320VX from ebay brand new.
Vizio 3632-1512-0150 Main Boards Replacement for ...
? 2:48
https://www.youtube.com/watch?v=a_8URZW356E
Dec 6, 2012 - Uploaded by ShopJimmy.com
Top Common Vizio LCD TV problems for bad Main Unit Boards:... To be best prepared to replace the Main Board inside of yourTV, you will need the following ... If you have any further questions regarding your repair, simply post a ... i can see on one of the small black squares (sorry i dont know what they ...
Vizio TV Repair - E601i-A3 Main Board Replacement for No ...
Dec 08, 2015 | Vizio XVT473SV 47 in. LCD HDTV
IR board location
Hey Tony,
The IR board will be on the inside of either the bottom center, left, or right of the front bezel.
Apr 03, 2013 | Samsung LN46A630 LCD TV
TH-50PZ85U 10 BLINKS
Check connector P11 and SS11 and make sure they are not loose. If they check fine, disconnect the connectors from the power board and che connector P1 and P11 for shorts. If you found a short, then replace the power board. If no short, then check SS11 for a short and replace that board if needed.
Jun 20, 2012 | Panasonic Viera TH-50PZ85U Plasma TV
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
My tv
Try unplugging it for 1 minute, replug, and see what happens.
If the above doesn't work, and If the TV simply fell hard and now you have the blinking red light there is a good chance you simply knocked out one of the main power connectors to the main board. Alas, there is also a chance you broke a connector too, but you won't know without opening the box.
If you are out of warranty and don't mind opening your LCD TV, you can open the rear and check for loose cables, or even a dislodged fuse.
The above is the easiest thing you can do.
Sep 06, 2008 | Akai LCT2715 27 in. LCD Television
Color/Pic problems Mits WD-65731
it sounds as though there is a problem on the main board and yes,it will be expensive to repair.i would guess between 400 to 600 possibly more depending on how much damage is on the main board. i know this isnt what you want to hear but i have a friend that has a tv repair shop and i know he gets big money for repairs on big screens.
May 26, 2008 | Mitsubishi WD-65731 65" HDTV
Television will not turn on as well
Hi, afraid Tvs aint somthing i fix but i found this service manual thought it might help. http://www.tradebit.com/filesharing.php/1/132 All the best John
Mar 02, 2007 | Pioneer PRO-100 TV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
