Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
NO video @ bootup
The computer turns on,fans all fire up,but no video of any kind screen is black ,bios does not show ,no beeping of mobo..A number of weeks ago a problem started where restart will not work ,had to cold boot computer each time ,but computer had video.
Components = Asus m2n slideluxe mobo ,AMD x2 5600 ,ocz 2g pc800 ,antec 620w truepower ,evga 8800 gts ,antec 900 case ,so lots of cooling.
Tried so far = reset cmos ,reset ram ,video card ,all components.. reset all plugs off power supply ,tries pci-e secondary slot ,swapped videocard from other (working) machine, swapped out different monitors ,keyboard and mouse ,disconnected all HD's ,so only fans and videocard on bootup...the only mobo beep I get is if I leave off the power cable to videocard...
  • BigD
    BigD Aug 05, 2008
    Doh!...Sorry ram is DDR2-800..(bad typo)...machine has run fine for 6 months...all components are factory approved for compatablity
  • hafizuddin Aug 06, 2008
    yes, i have same prob too.
    For your pc sake, i advise you to take your motherboard to nearest asus centre. May be, the service will 100% free if you have warranty..
I'm having the same issue...
HW is all compatible as per the Asus website...
What do I do now?
Posted on Aug 07, 2008
  • 101 Answers
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Posted on Aug 05, 2008
SOURCE:
How do i find model number of maxtone motherboard?
look at the bios cmos chip and take a note of the bios number .
then google search the bios number and you might find the type of motherboard from the bios chip number.
If computer shows post on bootup pause bootup with pause button on keyboard and note the bios number on the screen .
Feb 07, 2018 | Computers & Internet
Intel pentium - booting up ok, but nothing shows on screen. Pressed F12 came up with error message error setting up the MD3 over power button. Also, unable to locate media direct BIOS table.
If your computer is showing nothing on screen it is not booting up OK. Are there any beep codes being given during bootup? One single beep at the end of the POST sequence is OK, anything more means some kind of hardware error found during bootup. Media Direct 3 is a Dell product that has caused a number of problems on its computers. See Dell MediaDirect . Your option may be limited to contacting Dell support.
Jan 29, 2017 | Intel Computers & Internet
How do you turn on a Samsung R730 NP-R730-JA02US?
does it beep when it goes to black screen? if so it could be a B
IOS problem count the beeps and look up your computers BIOS system on another computer. The beeps indicate certain issues. Some of them are easily solved others are better left to a pro.If you have no beeps then it may be a burnt out power pack. If it's a desk top it's easy to fix. If it's a lap top is a little harder. Either way both if you have never opened a computer can be scary, Get a techy to look at it if you don't feel comfortable with tackling this.
Hope this helps a little
Jul 25, 2014 | Samsung R580 Notebook
Everytime i boot my pc,it beeps 2x,then black screen,so i have to reboot again
The beeping is caused by your computers POST( Power On Self Test - learn something new everyday! ;) )
Find your motherboard manual, and have a look in it for beep codes, or error codes. The number of beeps will let you know what kind of problem you're dealing with.
If all is well in POST, your computer should only beep once, and continue.
Can you get into BIOS at all, or does it just show you your videocard info on bootup, then black screen?
May 27, 2011 | Microsoft Windows XP Professional
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Building desktop: no beeps, no video The mobo LED are on, fan is running but getting no signal to monitor. I've tested the video card in another pc and confirmed working. The only time the mobo beeps...
If the cpu was bad- nothing would turn on--be sure the cable is good-- also be sure the VGA is enabled in the bios- since you cant see the video you have to reset the cmos setting--unplug the unit and remove the cmos battery-reinstall after one minute and check for video
Apr 10, 2010 | Intel Desktop Board D850MD Motherboard
Acer Aspire 9303wsmi display problem, 1 long beep, 2 short. HELP!
What you hear are bios beeps. They signal you that something is wrong. These beep's vary by the manufacturer of the bios chip that you have.
You can find out what bios you have by looking at your manual. The common cause for one long and two short beeps is a video problem.
Either the video chip on your mobo is shot, or your video card needs attention.
Hank
Aug 04, 2009 | Computers & Internet
Working SG-72 MOBOs failing 1 by 1, no POST after BSOD, just fans
test the cpus in other machines. if your not getting any boot or beeps, then it is the bios or cpu.
Jun 30, 2009 | Abit SG-72 Motherboard
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
MoBo speaker beeps while using computer
go into your bios and disable any kind of alarms related to your cpu or fans. hope this solves your problem.
Sep 20, 2007 | Abit IC7-G Motherboard
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
331 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
