Question about ASUS Computers & Internet
I wish to disable the built-in in mouse pad. - ASUS Computers & Internet
  • dg86960 Apr 03, 2011
    Thank you 4 the suggestion but it has no effect. I believe somewhere in the 'Boot up' stage there is access to activating/deactivating the built-in mouse pad. I do not c any reference to the mouse pad via the Control Panel/Hardware. appreciate your help.
4 Suggested Answers
  • 8 Answers
SOURCE: LAPTOP BUILT IN MOUSE PAD
depending on what laptop you got i got an acer spire 5751z and it can enable or disable the mousepad by pressing 2 keys on the same time:
<FN><F7>
let me know what laptop you got or how it worked out
greetings
Posted on Jan 02, 2009
  • 400 Answers
SOURCE: disable track pad when using the mouse on advent 6311
Do you want to disable the onboard touchpad while you use an external mouse?
To do this there should be a key sequence on the laptop like Fn+ F8 (or another key) it has a mouse symbol on it.
Posted on May 11, 2009
  • 309 Answers
SOURCE: Happy New Year! I wish to disable my touch pad and
It is a software setting under Control Panel / Mouse. Look for the setting for "enable / disable" and choose the appropriate setting.
Posted on Jan 04, 2010
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
Cq60 frozen mouse pad
Since you don't seem to want to help us in helping you, by being more detailed about your mouse, or mouse pad, problem, I will give you some general advice:
- This is a laptop, yes?
- It has one of those little areas where you can use your finger, instead of a mouse?
- Look in Device Manager, or even in the Mouse option in Control Panel, and see if you have a mouse configured for your laptop, in addition to the built-in finger pad for use as a mouse.
- If you find there are two separate devices, one for the laptop-supplied mouse square, or rectangle, with the buttons on the bottom, for use instead of a mouse, and one for an external mouse, then make sure you have designated the built-in pad for use as a mouse. If, however, you want to use an external mouse, then you do the opposite, and ensure that the external mouse is selected as the device you wish to use for a mouse, and disable the built-in mouse/finger pad software, so that you do not have a conflict.
One or the other must be primary, and the one not primary must be disabled, or your laptop must be told not to use that other one.
Apparently - again, because you gave us absolutely no details - there is a hardware conflict and the laptop doesn't know which device to use, so it is not using either, and you're stuck without the benefit of any pointing device.
All the work you need to do with device manager and control panel must be done with keystrokes, and for that you must use Windows' Help to learn which keys will do what. Usually the four arrow keys, near the numeric pad, along with Page Up and Page Down, and the Tab button, or Shift+Tab, to go backwards, are all you might need to reset things the way they need to be set.
I hope you understand that absent any details at all, the only advice you will get from anyone here, is going to be educated guesswork.
Best of luck to you.
Cheers!
-a.
Jun 16, 2012 | Compaq Presario CQ60215DX PC Notebook
I would like to disable the touch pad and use an external mouse. Sony Vaio VGN A190
Please follow the steps to disable the Touchpad under XP environment:
First, click the Start button, then click VAIO Support Central .
In the VAIO Support Central window, in the left pane , click System Maintenance .
In the right pane , click VAIO Central .
In the VAIO Central window, click the System Information tab.
On the System Information tab, click the Plus symbol next to Keyboard and Mouse .
Under Keyboard and Mouse , double-click Built-in Pointing Device .
In the Built-in Pointing Device window, click to clear the Enable box.
Click the OK button.
In the Built-in Pointing Device dialog box, click the Yes button.
Thanks!!!!
Dec 24, 2010 | Sony VGN-A190 Notebook
Laptops built in mouse not working. can coonect an external mouse and it works fine. thinks granddaughter pressed a button disabling it. how to fix
Hi, I suggest that the function key F9 has been pressed, this locks out the pad. To turn the pad on again, press F whilst holding the function (Fn) key down). Regards, Brainschee
Nov 27, 2010 | Toshiba Satellite L305-S5933 Notebook
I use a hand held mouse. How do I disable the finger mouse
If by 'finger mouse' you mean the touch pad then yes you can enable or disable it as you wish.
For Acer Aspire models you need to press and hold the 'Fn' button and then press the 'F7' button (It has blue square on it with a hand over it).
Repeat the process to enable the touch pad.
Jun 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
<FN><F7>
greetings
Jan 02, 2009 | Computers & Internet
Mouse Pad and Right and Left Buttons
Great job, I myself prefer to use a extra mouse rather then the built in one, if you chose to do this it wont work right away but if you give it a moment to recognize the mouse it will then be functionable.
Jan 04, 2008 | Toshiba Portege M400 PPM40U01000E Tablet...
Computers & Internet Logo
19 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
