Question about Samsung B3410 Cell Phone
Not support you tube - Samsung B3410 Cell Phone
  • 410 Answers
Most of the phones support .mp4 n .3gp for mat of any video but you tube vedios are in .flv format which r not supported bye the phone so you must covert them to the desirable format of your phone before running them to your phone.....after conversion send them to phone n run them they will run....
Posted on Apr 03, 2011
Can i upgrade my b3410 netfront browser?
Posted on May 26, 2011
Tip
Brass Tube Fitting
The essential step of tube fitting production include heating, melting, mixing and conveying the raw material into a particular shape. It is important that this shape is maintained during the cooling process. All Brass tube fittings are made in accordance with ASTM standards. All diameters of solid wall Brass tube fittings are continuously extruded through an annular die. Thermoplastic fittings are either injection or compression molded. They are fabricated using section of pipes or machined from molded plates.
Om Tubes Brass Tube Fitting connects different types of tubes to one another. It can be used for in-line, offset, multi-port, and mounting configurations. Various tubing sections like pipe, hose, or other components are connected through tube fitting. Usually the system is configured with straight sections connected by fittings or some specially formed connections and joints. Om Tubes being Brass Tube Fittings Distributors provides you with best quality & services. Products at Om Tubes are of various wall types and all are produced in accordance with the requirements of a variety of industry standards and specifications like ASTM and AWWA. We sell Good Quality Brass Tube Fitting at Om Tubes.
http://omtubes.com/brass/brass-tube-fittings
on May 08, 2017 | Miscellaneous
`fix tubing that has leaked
The heat from the light bulb dried out the plastic hose on the dispenser. the tubing is 1/4 in and I used a brass compression fitting brass insert . I cut off the head of the insert so the tube was round and could be used to join a short piece of plastic tubing to the existing plastic tube in the door. Cut off the damaged section of tubing in the door and replace that length with new plastic tube. Push the brass insert halfway into the new plastic tube and then into the existing tube in the door. Route the tube into the original metal part on the door and it's done.
Sep 23, 2014 | Refrigerators
Diagram assemble for pushrod tubes on 1983 shovel head
corks top and bottom. small tube on top with o-ring down. large tube on bottom with spring and cap up. slide pushrod through tubes. Hold tubes up with a piece of wire and adjust pushrod. Remove wire and extend tubes from lifter block to head. Depress cap and install spacer between spring cap and top of top tube.
Sep 01, 2014 | Motorcycles
Where is the orifice tube on a dodge intrepid 1999
what is an orifice tube? gas fill tube? oil dipstick tube? trans dipstick tube? tailpipe?radiator coolant overflow tube ? tube top? vacuum tube ?
Jun 28, 2011 | Dodge Intrepid Cars & Trucks
How do you remove broken oil dipstick from a 1999 ford escort?
The dip stick tube is pressed into the engine block. Put a bolt into the top of the tube so that the body of the bolt goes into the tube and the bolt head rests on the tube (so it does not fall down the tube). Use a wrench (such as a Vise grip) to hold onto the tube at the bolt and gently work it back and forth, being sure not to deform the tube. Remove the tube and old dip stick. Replace the tube by forcing it back into the eng. block. Replace the dip stick - done :)! Some dip stick tubes have a gasket at the engine - others just **** up to a shoulder that is built into the tube. Let me know if this works. Thanks.
Dec 19, 2010 | 1999 Ford Escort
My 2005 Equinox has a broken EGR tube, I need to get a replacement tube. Can you please get me the part number?
My tube broke several years ago. The original tube is longer than the replacement. Evidently the GM was unable to make a long tube that would not break. You have a long tube if the input of the EGR (where the tube connects) is higher than the output (where the EGR connects to the intake manifold). If you have the longer tube, you must purchase a replacement from GM which is $200 and includes the short tube, new design EGR valve and a new connector to replace the old EGR electrical connector.
Nov 07, 2010 | 2005 Chevrolet Equinox
I need to replace a 16.125 tube with a 16" bell universal tube. The universal tube appears to be too large for the rim and the website is under construction where I should be getting the insructions.
the 16"tube cant possibly be too big to replace a 16.125 tube unless it was the wrong tube to begin with,check the tire to see if the proper tube size is located on it
Jun 01, 2010 | Bell Sports Bell Universal Bicycle Inner...
Types and sizes
TUBE WITH THEIR STOMACHS FACING DOWNWARD, OR TO SIT IN THE MIDDLE OF THE TUBE WITH THEIR BOTTOM IN THE "DOUGHNUT" HOLE. DECK TUBES: A SLIGHT VARIATION ON THE STANDARD "DOUGHNUT" TUBE IS THE DECK TUBE. THE DECK TUBE IS SIMLAR TO THE STANDARD IN THAT IT IS USUALLY ROUND IN SHAPE BUT WHAT SETS IT APART IS THE LACK OF A HOLE IN THE MIDDLE. DECK TUBES COME IN ALL SIZES AND ARE USUALLY RIDEN WITH THE RIDER FACING DOWNWARD ACCROSS THE TUBE. DECK TUBES ARE USUALLY DESIGNED WITH HIGH PERFORMANCE RIDERS IN MIND WHO SEEK SPEED AND THE ABILITY TO PERFORM TRICKS WITH THE INFLATABLE. ENCLOSED TUBES: ENCLOSED TUBES ARE NOT MUCH DIFFERENT THAN THE OTHERS EXCEPT THAT THEY ENCLOSE THE RIDER WITHIN THE TUBE AND GENERALLY DON'T ALLOW AS MUCH VERSATILITY ON HOW TO RIDE. ENCLOSED TUBES CAN BE GREAT FOR FAIMILIES WITH YOUNGER KIDS OR FOR PEOPLE WHO PREFER A MORE STABLE, DRY RIDE. CONCEPT TUBES: THERE ARE OF COURSE AS MANY OTHER DESIGNS OF INFLATABLES AS THERE ARE PEOPLE WILLING TO RIDE THEM. OTHER POPULAR "CONCEPT" DESIGNS INCLUDE TUBES SHAPED LIKE SNOW SLEDS, SPACE SHIPS, AND HOT DOGS! SINGLE RIDER TUBES: SINGLE RIDER TUBES ARE SO NAMED BECAUSE THEY ACCOMIDATE ONLY ONE RIDER. BECAUSE OF THIS, SINGLE RIDER TUBES TEND TO BE SMALLER AND LIGHTER THAN OTHER TUBES. THIS MAKES THEM GREAT FOR HIGH PERFORMANCE TUBING INVOLVING JUMPS, TRICKS, AND HIGHER SPEEDS. ANOTHER BENEFIT OF SINGLE RIDER TUBES IS THAT DUE TO THEIR SMALLER SIZE, THEY ARE GREAT FOR JET SKIS AND SMALLER, LIGHTER BOATS WITH LESS HORSEPOWER. DOUBLE RIDER AND MULTI RIDER TUBES: DOUBLE RIDER AND MULTI RIDER TUBES ARE DESIGNED TO CARRY MORE THAN ONE RIDER AT A TIME AND WILL TEND TO BE SLOWER, HEAVIER, AND LARGER THAN THEIR SINGLE RIDER COUNTERPARTS. WHEN TOWING A DOUBLE OR MULTI RIDER TUBE, IT MAY BE NECESSARY TO USE A STRONGER, HEAVY DUTY TOW ROPE AND TOW HARNESS TO ACCOMODATE FOR THE INCREASED WEIGHT. BECAUSE OF THEIR LARGER SIZE, THESE TUBES ARE GREAT FOR FAMILIES WITH CHILDREN OR REALLY ANY GROUP OF PEOPLE THAT LIKE BOATING AND WATER SPORTS. MULTI RIDER TUBING IS ALSO A GREAT WAY TO MAKE SOMEONE COMFORTABLE WITH TUBING IF IT’S THEIR FIRST TIME ON THE WATER.
Dec 01, 2008 | 3M SportsStuff Speedzone 3 Inflatable...
Samsung B3410 Cell Phone Logo
102 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
