Question about Maytag Neptune MDE5500AY Electric Dryer
WHy is it when i reversed the door on my maytag neptune the fault code is DO.. i checked it.. and it looks like when u change it to swing from the left it doesn't push the button in that lets it turn on
  • Maytag Master
  • 3,053 Answers
Hello, nauf I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
this fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
Feb 26, 2016 | Maytag Neptune MAH9700 Front Load Washer
Maytag neptune mah5500b sr code
Machine control is attempting to drive the motor but is not seeing any tach response.
Visual check shows motor is not moving. (Locked, Hall Sensor fault).
Evaluate wire harness for loose or unhooked connections.
Oct 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
Maytag dryer
remove the 2 kick panel screws near the front panel by the floor swing the front panel upward and the top clips will release,then remove the 2 hex head screws under the top cover then swing the top cover up like a car hood and secure it so it doesn't fall and pull wires out,then remove drum and restring belt and then around the drum then around the tensioner and reverse the above procedure
Apr 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you reverse swing on door
Ity is not normlly possible to reverse the door on automatic washers, as they are not configured for this.
Tthankyou.
Dec 19, 2009 | Maytag EPIC MFW9700S Front Load Washer
Rotate the doors
You can reverse the doors and it is not very hard to do.If you need assistance I'll be happy to provide the help to do this.
Apr 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytg neptune
FL fault code means door failed to lock. Could be misalignment between the lid and the locking mechanism. Try the service mode and see if you can get the door to lock. Otherwise you may need to replace the lock itself.
Feb 21, 2008 | Maytag Neptune Washer
Maytag dryer
Take off the door then remove the screws on the other side (where the door would be attached if it were reversed) You can now swing the front panel down from the top.
Dec 25, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Reversable doors?
yes indeed both the washer and the dryer doors are very easily reversible. How much are you getting the set for?? Im tryin to sell a mint 03 5500 washer for $400 and was wondering if that was a little high or not.
Nov 17, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MDE5500AY Electric Dryer Logo
35 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
