Question about Garden
I have an 1822 grasshopper front deck mower. In the manuals I have nowhere does it tell me not to push or pull the mower without power. I see on the side of the motors an unloader nut with a long screw in the center and a clip into each side of the unloader head
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
  • 127 Answers
SOURCE: Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Posted on Jun 30, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
jdlipscomb41
  • 157 Answers
SOURCE: I have a Grasshopper zero turn mower that uses
yes just reguler hydralic oil it wont hurt a thing. but dont use atf its for transmissions in vehicles
Posted on Oct 26, 2009
  • 29 Answers
SOURCE: Describe your Riding Mowers &
You can go online to the tractor company and look up the owners manuel online. Most decks will have a placard that shows routing. look under tractor on top of deck.
Posted on Aug 27, 2011
Where is the oil drain plug at on a grasshopper zero turn lawn mower model 1822
it's on the bottom of the motors oil pan, but if you find it too hard to get to, there is a suction device that pulls the oil out the dipstick tube
I have never tried one of these Walmart Oil Change Pump Kit
the one I have is a vacuum pump up style and they are about $150 Oil Extractors
Sep 03, 2015 | Garden
What is the drive belt diagram for a model 616 grasshopper lawnmower
check the deck carefully it might be written on the right side
Sep 18, 2014 | Garden
How do you remove a field assembly with brake off of a 721d grasshopper lawn mower
you question makes no sense to me. ask it a different way or tell us what your trying to do. Are you trying to move the tractor ???
Jul 11, 2014 | Mtd Drive Belt 42"
How to remove mower deck of grasshopper 720
Contact the manufacturer/distributor directly to obtain the information.
Nov 25, 2011 | Garden
I have inherited a ride-on tractor, Husqvarna LT19538, without an operators manual. Can you please tell me how to start it?
Make sure you have gas, oil, and a fully charged battery.
Sitting on seat, push the clutch/brake pedal down fully, make sure the mower PTO is in the "off position". Push throttle control to choke, or pull the choke handle, whichever set up you have, and then turn the key.
Sep 20, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Describe your Riding Mowers & Garden Tractors Problem looking for deck belt diagram and size for a 52 inch grasshopper mower series 620
Aug 27, 2011 | Garden
Wher can i find parts for 54 in. deck [ bearings] etc.
I HAVE PARTS FOR THEM IF YOU WANT YOU CAN CALL ME IF YOU WANT 918-728-1822
Aug 22, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
