Question about Craftsman Garden
Have an older 4 cycle cultivator edger wont fire. am getting spark
  • Craftsman Master
  • 7,482 Answers
Check your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 09, 2011
Ryobi ry64400 will not start?
  • Does it have spark?
  • Does it have compression?
  • Is fuel getting into the cylinder?
    More information required. Thank you
May 23, 2016 | Ryobi 10 in. 30 cc Gas 4-Cycle Cultivator...
What spark plug is used in an unidentified trimmer/edger?
Ryobi 4-Cycle Spark Plug-AC00164A - The Home Depot
www.homedepot.com/p/...4...Spark-Plug.../203222932
The Home Depot
Rating: 4.3 - ‎3 reviews - ‎$4.97
6 days ago - Keep your engine running smoothly with the Ryobi 4-Cycle Spark Plug forTrimmers. ... Use the replacement spark plug with any of Ryobi 4-Cycle engines. ... Replaces champion RY4C and torch CMR7A.
2-Cycle OEM Spark Plug (RDJ8J) - Sears Outlet
www.searsoutlet.com/2-Cycle...Spark-Plug.../product_details.jsp?pid...
Shop for a 2-Cycle OEM Spark Plug (RDJ8J) (49M0311P953) at Sears Outlet today! We offer low prices and great service.
Nov 28, 2015 | Garden
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
It wont start,I replaced the spark plug
Joe try putting some fuel in where the spark plug goes. If it still doesn't fire then proceed to eliminate things. Firstly the air filter will need cleaning then the spark coil. If it still don't fire check the switch is ok. Sometimes the switch breaks a circuit and helps with the running of it.
Dec 01, 2013 | Ryobi Expand-It 2 Cycle 26cc Trimmer Power...
It will not start
pull the spark plug out and check to see if it is wet causing a flooded situation. I am willing to bet however that the carburetor diaphragms have dried out requiring a rebuild or replacement. with the low cost of carburetors I generally just replace them since it is cheaper for the customer than to rebuild one
Mar 30, 2013 | Troy-Bilt 4 Cycle Cultivator / Edger...
I HAVE TRIED ALL THE IDEAS REMOVE SPARK PLUG,INSERT SMALL AMOUNT OF GAS ETC. IT HAS GAS AND FIRE BUT NO START
if you say it has fire,then the small amount of gas you poured into the spark plug hole will fire if theres a spark,if it does fire when this is done its your carb thats fouled up,remove the air cleaner from the carb and when it fires,take WD-40 and spray it into the carb where you removed the air filter&cover and see if you can keep it running,also did you remove the sediment bowl off the bottom of the carb to see if and how much water/dirt is present in this bowl???
Mar 22, 2011 | Honda 25cc 4-cycle Mini Tiller
Honda 4 cycle cult wont start. New gas primer primes new spark plug. Won't fire.
Check the start switch and the start switch line. If not broken, check the choke switch and try different settings to start it. Last check the gas line for any cracks. This tiller can be easily be flooded when pushing the prime button..
Jun 25, 2010 | Honda 25cc 4-cycle Mini Tiller
I have a weed eater edger has spark , getting gas but it wont fire
How much compression do you have, also how long have you had it, sometime the muffler will plug because of the 2 cycle oil,And will not let it breath
Apr 12, 2010 | Garden
Won't start. have replaced plug and cleaned filter. any suggestions?
check and see if your coil is grounded,if not clean flywheel magnet and check for spark if no spark replace coil,
Jul 28, 2009 | Mantis 4-Cycle Tiller/Cultivator with...
The cultivator is getting gas, the plug looks new but no fire
Check Compression, if you dont have a gage put your finger in spark plug hole it should blow it out.
Next check for spark,It should be a blue spark at plug.
Next put a little fuel in carb and see if it will fire.
Hope this helps. Let me know.
Mar 22, 2009 | Yard Machines Cultivator
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
