Question about Whirlpool and Maytag Washer Accessory
Looking for service manual for Maytag Washer model SAV365AAWW
How to tighten the belt of Maytag washer model SAV365AAWW?
Depends how good you are with disassembly. It's not that difficult and you need to shut off the water and unplug the machine. The front needs to be removed and on the bottom is where the belts are. Loosening the pump retention screws and pulling the pump towards you while you tighten at least 1 not to hold the tension. Then tighten the other screws on the pump and reverse disassembly order. Too tight on the belt will burn your pump up and of course too loose will allow them to slip. I would look and see why the belts are slipping. Water leaks, worn out? For the proper tension, on the center of the belts, you should be able to press your index finger on it and it will push in about 1/2". Good luck
Apr 18, 2017 | Maytag Washing Machines
Maytag e2l manual
Hi, I found the following sites which you may find useful:
http://www.maytagclub.com/ look for the "Restoration info" on the left of the screen.
or
Maytag Electric and Gas Wringer Washer Service Manual
or
Maytag E2 Wringer Washer Parts Manual
or you could try asking "Maytag" if the have a copy of the manual at the following link
Help Contact Us Maytag Refrigeration Cooking Dishwashers Laundry Appliances
Trust this helps, regards Alan
Aug 22, 2015 | Maytag Model E2l Vintage Wringer Washer...
Complete list maytag error codes
This was taken from the MAH8700A 27" washer service manual, I'll look for the 8700 if I have one, since Samsung made both of these models, I think the failure codes are the same. Pleazer Appliance...
Apr 14, 2014 | Maytag Neptune MAH9700 Front Load Washer
Hello - basic question - How do I open a Maytag Nepture Top-load Washer, model # fav6800aww? It is leaking water and i want to look for the leak. thanks. Marty
See the following Maytag / Neptune Service manual, it should help.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
Dec 10, 2010 | Washing Machines
Maytag Washer Drum is broken, how do we remove it properly and replace with new one??
Model numbers help us tremendously.
I believe this Factory Service Manual covers your machine.
If not,give a model number for a more specific manual.
cut and paste this link:
http://www.servicematters.com/maytag_library/docs/16023110.pdf
Sep 06, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag mav6000awq repair manual
No I don't. Also I couldn't find the model on the pull down but the Maytag is 745G model LAT8650AAL
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool and Maytag Washer Accessory Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
