Question about Whirlpool Washing Machines
Model wfw8300sw05 washer, part # ap4340286 water level switch. I know big brother doesn't want me to do this, but I would like to raise the water level during wash and at least 1 rinse cycle. There appears to be 5 sealed adjustment screws with 6 wires to sw. This leads me to believe that ea. screw controls level for diff. cycles. Unlike old WL switches w/ 1 screw where it is turned CW to raise level, I'm thinking a CCW turn would work here, moving the elec. contact further away from the diaphram. If I'm right, which screw controls which cycle? Thx, Dave
  • 6 more comments
  • damills73 Apr 03, 2011
    This switch is not like the typical sw. It has 6 wires, all blue, going to controller. Washer does not have water level selection. I can't believe this SW is only used on one model or that mfg. is so precise that no adj. are necessary. On the face of the sw are a couple slots where you can see the diaphragm and it appears to be brass or plated which led me to think it was used as a contact surface. I may be mad, I may be a scientist, but not both.
  • damills73 Apr 04, 2011
    I think that everything designed and built is a compromise. If true then anything can be modified to improve for someone. Therefore, don't mess with it is not an answer. I could buy a valve, experiment and test it, but why then would I need a site like this? Someone must have access to a schematic that can answer my question.
    OK, so why do suds increase load on motor? I would think suds would make things more slippery. Also wouldn't make-up of load do the same, eg. a load of sweats vs sheets and pillow cases? One would hold much more water and be heavier. Or what about a larger or smaller load on the same cycle? Also, machine has suds overflow duct to get suds out of machine. I can't quite get my head around this one. ???
  • damills73 Apr 05, 2011
    Thanks, Mo, for the reply. I don't mean to be disrepectful, as I have washed dishes and tended bar so I know what you're saying, but I don't see the connection between solids (glassware) and porous fabric. Also, what about different size loads, fabric types etc? Is your opinion based on Whirlpool tech data or your experience? If on tech data, can you tell me if the switches in the level control are NC or NO? Thanks again, Dave
  • damills73 Apr 06, 2011
    Only manual that came w/ machine was consumer cycle descriptions, how to use, etc. No tech stuff or schematics. As to the wrong part #, sorry, got it from Whirlpool parts supply site incl. pic, so I know it is right. I don't need any platitudes about how it's designed to work etc. but I understand unwillingness to provide info that you think might get you in trouble but I also believe in personal responsibility and accept it. I'm about ready to give up on this site.
    Rick, go to appliancepartspros.com. There you can find the AP part with pics, front and back. Thx
    I don't know how to post a link, see, I am an idiot!
  • damills73 Apr 07, 2011
    Sorry, Rick , about late response, had trouble finding your comments. My bad about part #. At the time, I was so glad to find the part I thought I was on a Whirlpool site. My machine works as it is supposed to and I have not replaced any parts. I would just like a little more water in the wash cycle. I also understand personal responsibility and do not blame others if I do something stupid. Now, if you would be kind enough to answer my question, I would be grateful. Thanks, Dave
  • damills73 Apr 08, 2011
    Thanks, Rick, just found your last post- I'm not very good at this, hope I'm learning. No level selection, just different cycles. I was hoping to eliminate the guesswork and experimentation. Thanks anyway for trying. Dave
  • 1,998 Answers
Noooo there all gonna laugh at you lol no just kidding the water level switch aka pressure switch does control how much water the machine fills up with Water level switch, located inside the console, is used in controlling the amount of water entering the washer. There are different water levels, depending on the model you have. Selections might include "extra small", "small", "medium", "large" and "extra large", plus a "reset" option. Some models have a fixed water level switch. This allows for just one water level in the washer. you need an Ohmmeter to test the water level switch. There are three color-coded wires going to this switch: violet (V), pink (P), and tan (T). The violet wire carries the current (electricity) from the timer to the water level switch. Contacts inside the switch send current back through either the pink wire, meaning an empty tub, or tan wire, meaning a full tub of water. this should give you a bit more information about the water level switch also the tube that comes down from the water level switch is also controled as to how much water by that tube that comes off the switch and plugs into the drum as well hint hint If you have any further questions message me back we arent able to tell how to change the engineering specs to a unit although we all love a good mad scientist message me back if you have any further questions Thanks Rick
Posted on Apr 03, 2011
  • 1 more comment
  • Rick Ead
    Rick Ead Apr 03, 2011
    btw that part number does not come up for your machine for the water level switch the actual number would be W10163980 as you can also see on this linkhttp://www.searspartsdirect.com/partsdir... i actually have no idea where you got that part number from i said your like a made scientist becuase your trying to adjust the water level higher then the factory preset of how the machine is engineered to work Thanks Rick
    p.s I can see that now if someone where to tell you about adusting the water leveling switch above the factory preset and then it flooded your basement what a wonderful law suit that would be Check your part number because the one i have listed along with the link is for the actual part
  • Rick Ead
    Rick Ead Apr 04, 2011
    why not try getting the right part for your machine that one with the ap # is the wrong part and probably why you dont have enough water in your machine also if we were to tell you how to go against the manufacturers recommendations and something were to happen to you or your house then you could actually hold us liable for that information due to patents on the machine Thanks Rick
  • Rick Ead
    Rick Ead Apr 06, 2011
    sorry bud i could tell you but im not willing to accept the liability of you changing the manufacturers recommendations and take a look at this link http://www.searspartsdirect.com/partsdir... appliance parts pros have there own part numbers or take that part number on the sears site and compare it to appliance parts pros and see if the two parts are similar heres what repair clinics looks like http://www.repairclinic.com/Shop-For-Par... and repair clinic doesnt recongnize that number either i would suggest you call them on this link though http://www.appliancepartspros.com/part_d... seeing how it is there part and they could assume liability for you changing how this piece performs Thanks again Rick
EXPERTS (manufacturers) make the washing machine to confirm to Government standards.And DOES not mean that by lessening the water level is in ANY way better.pure ignorance to think "more" water would make your wash come out less clean. Sir, There is a water level knob located in the control panel.use screwdriver to click once to improve water level.And all you people that have the front in loaders with all the watered down detergent, may I let you in on a little secret.I have had my front end loader over 10 years,longer than alot of you.I tested the washer one afternoon while on lower water level,spun the load, put it into a regular washer in garage and the water turned light brown due to dirt etc. left in the clothes.By all means,up your water level and don't be dis-informed by those posting that clearly haven't done their homework.
Posted on Oct 19, 2012
  • clearlakeguy
    clearlakeguy Oct 19, 2012
  • Whirlpool Master
  • 8,220 Answers
Dave if you monkey with the water level, the motor will draw more amps. The central control unit monitors motor amp draw and if it reads over-amping then it suspects suds are in the wash-load. So that causes the system to do a series of mini-washes to eliminate any extra detergent in the wash.
After 6 attempts the washer declares an error and comes to a screeching halt. So you would be doing yourself a dis-service by attempting to change the water level. My opinion.
Duet Sport Service Manual and more HERE
Posted on Apr 04, 2011
  • Dan Webster
    Dan Webster Apr 05, 2011
    Why do suds increase load on motor?
    You ever reach into the sink and grab out 2 glasses from the soapy water that were stuck together? The action from the sudsing locks the 2 glasses together.
  • Dan Webster
    Dan Webster Apr 06, 2011
    The whole idea behind these washers is to save water as well as power. They conserve water by using HE detergent in sparingly quantity's and very little water. Go using any old detergent and yall will have errors galore. Put the correct detergent in the wrong dispenser and you will have problems. To rectify any conditions from daily wash the manufacturers have a washing machine cleaner yall add every month or so.
  • 4,399 Answers
Thanks for choosing FixYa and welcome. Dave, do you have your manual?
Posted on Apr 06, 2011
  • 2 more comments
  • Richard Hale
    Richard Hale Apr 06, 2011
    Dave, for some reason, I didn't see your response. I read on your page a little. It can be done. You are right about that. What I am trying to find is a picture of the switch. You are at the right place Dave. I have did this before, but not to this model. In the two that I have did, it is the screw at 1 o'clock, the first one going clockwise. I only set it for wash though. I never did it for a washing cycle.
  • Richard Hale
    Dave, I don't know why I can't see any of your responses. This has never happened before. All I can is they should be in a specific order, from level to rinse, in that order. So sorry. I will have to look into this. The other questions appear but your does not.
  • Richard Hale
    OK Dave, I found your response. Give me a second to check out this site.
  • Richard Hale
    Richard Hale Apr 07, 2011
    Hey there Dave. Sorry for the late reply. I have looked everywhere to find out which screw controls what and I can't find nothing. I am not familiar with this exact type. I would think it would be left to right, right side first. So, on the right side, it would be 1, 2, and 3. Then, on the left, going right to left, 4, 5, and 6. You really posted a great question, but it can be done. All I can really say, if you don't find an answer, is adjust number one and examine what it does. I saw nothing in the manual I downloaded about the specific screws and cycles. Does your washer have 3 levels? If so, you may be looking at a screw for each level, low, medium, and high. Then, one f'or wash and one for rinse on each setting.
  • 1,543 Answers
Front load washers are designed to use a low water level. If you select a delicate cycle, you will get a slightly higher water level, which results in a gentler wash action. Therefore, even if you succed in raising the water level, you will decrease washing performance. The engeniers and product testers have done their work and know what works best. Don't second guess the experts. Leave the water level alone!
How to raise the water level on my LG washer
There is no need to raise the water level. all modern washers automatically add the amount of water needed to wash the amount of clothes that you put in, I could explain how, but it will put you to sleep. rest assured these machines pretty much look after themselves. I would be more interested to know why you think it needs more water, are you having rinsing issues? wash quality issues?
Oct 07, 2016 | LG WM Washing Machines
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
I have a GE washer model GBXR1060T. Some time the water gets over the tub and is spilling on the floor. We have to close the water source valve to stop the water entering in the tub. I see on the side of...
If the water shuts off when you push the timer knob in then the most likely failure is the water level/load size switch or the air tube connecting the air dome and water level switch has developed a hole in it or it may have pulled off from the water level switch. If you have to shut the cold/hot water faucets off in order to stop the water then the water inlet valve has failed open. I added instructions in the image below on how to access the water level pressure switch in the console and how to remove the front panel and raise the top. You will need to inspect the tubing connected to the water level pressure switch and where it connects on the lower side of the outer tub. If you do not find it disconnected or any holes in the tubing, replace the water level switch. richroth_152.jpg
Aug 20, 2011 | GE WBSR3140DW Top Load Washer
There does not seem to be enough water in machine to wash with
This problem could have a number of different causes. Unless it is a machine specifically designed to operate at reduces water levels, the likely cause is that the sensor that determines how much the machine fills up is somewhat blocked or going bad. The blockage would prevent accurate sensing of the water level. See the explanation below:
The level sensor uses a pressure switch to detect the water level in the tub.
Water level control switch
This switch controls how high the tub fills with water.
Water level control switch plumbing
The big end of the hose connects to the bottom of the tub, while the small end connects to the switch. As the water level in the tub rises, water rises in the hose also; but the air in the hose is trapped, so as the water rises, the air is compressed.
Inside the water level control switch
Inside the housing of this switch is a little piston. The pressure in the hose pushes the piston up. When it is raised far enough, it pops up and closes an electrical contact. This set point, where the contact is lost, is adjustable, and in the picture you can see the cam mechanism that is connected to the adjuster knob on the control panel of the washer. As the cam turns, it presses a spring against the cylinder, making it harder for the cylinder to pop up. This means that the water level will have to rise some more before the pressure in the hose will be high enough to trigger the switch.
Aug 11, 2011 | Washing Machines
Roper washing machine RTW4440XQ, my mom sets the load for medium and when it is going to fill with water the second time before rinsing it only fill with water as if it was a small load. Does it have a...
All new washing machines in the US, as of 2011, must comply with Govt energy regulations. Save water & Destroy your clothes! This model has 2 pressure switches. The main one (on the left) controls the wash water level, and the rinse level switch (unseen, mounted to the right, controls the rinse water level. BOTH ARE ADJUSTABLE ! First - UNPLUG THE WASHER ! Tilt the control panel back. You will see the two pressure switches. In the center of each is a silver adjustment screw going into a white plastic plunger. Using a 3/16" socket or nut driver, turn the screw on the RIGHT SIDE pressure switch clockwise until it is almost all the way in to the white plastic plunger. The next step is a little trickier. Being careful not to touch any wires, Plug the washer in, Set the water level to HIGH, and start the washer . Raise the Lid, and observe the incoming water. It will stop when the pressure switch is satisfied - but the water level will be rediculously low. As you did with the Right side switch, adjust the LEFT side switch the same way - only 3-4 turns at a time. After each adjustment, push the white plunger in and it will begin to fill again. When it stops filling, check the water level - you may have to repeat this step 3 or four times, until the water level is 3 - 4" below the white plastic guard on the tub. That's it, Unplug the washer again, tilt the control panel back down & lock it in place. Plug the washer back in, lower the lid & let it run through the cycle. This repair will probably void your warranty, and is not recommended to ANYONE who is not familiar with tools, machinery and electricity. To those who can, **** the torpedoes and full speed ahead ! To those who can't, show this to your repairman. The advantages are 1- Cleaner clothes 2- Less damage to clothes 3- Less wear & tear on the machine, as it doesn't have to work as hard moving the load in too little water.
May 24, 2011 | Roper Washing Machines
The water level on my FWS933 does not fill all the
Check the water pressure switch. You can trace this switch by following a small water hose running into this switch. See whether any adjustmnents present. ( just a guess only- as there are many designs )
Mar 30, 2010 | Frigidaire FWS933F Top Load Washer
WM0642HW LG water level is too low.I want to get more water in it. Any suggestions? Is there any way i can override sensors so i can get about 5 gallons more water in it?
YES YOU CAN RAISE THE WATER LEVEL ! Raise the top of the washer lid by removing the 4 dispenser screws. Push side of dispenser tabs to drop dispenser down off from lid. Using an opener or flat item, insert into lid front edge to depress inward the metal top hold down clip. Do the left side first then the right side. Raise the lid.You'll see the water level sensor switch on the inner cabinet upper right side. You will see a set screw for a phillips screwdriver. Slowly turn that screw CLOCKWISE about a quarter turn. With washer cylinder emply,and holding detergent dispenser assembly upright so it won't spill water into inner cabinet area, start the washer.You will see the water level rise to a higher set point than just to the edge of the gray cylinder baffels.I have set mine to fill to the edge of the rubber door seal. I wouldn't go any higher than that. I see no need for the water level going over onto the glass window area.Ever since i raised the water level so my clothing tumbles in water instead of wicking up water as before and only becomming fully saturated nearing the end of the wash segment. The new adjustment has ended all of the complaints i had earlier about this washer not cleaning or rinsing well. My laundry is clean the first time around and all my washer needed was a few more gallons of water to work with. LG themselves were of NO help when i called dozens of times before .They just gave me the run around and never a straight answer about the water level except nothing could be done, it was based on laundry load weight, too bad so sad. That was TOTALLY UNTRUE! I found out how to adjust it by another owner of the LG WM0642HW posting this info on how to raise the water level, and how to go about doing it.I've not had to do a single rewash since turning that water level switch higher.Honestly!
Mar 15, 2010 | LG WM0642H
My Kenmore 70 is also overfilling...
Sounds like it could be a faulty water level switch. A defect or an obstruction can mean that it can't tell the water to shut off. This switch raises the water level in the clothes tub. It's usually a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, the pressure increases on the air in the plastic tube. When the pressure reaches a certain level, it activates the switch and turns off the water. It also signals the washer to begin the wash cycle. Clean out any obstruction in the plastic tube or replace the water level switch. Hope this helped.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Washing machine
remove the left and right edge trims on the control panel
remove the phillips screws under the edge trims
raise control panel ~1 inch and flip over backwards.
  • ensure air tube is attached( water level sensor operates off air tube from bottom of drum to control body, (bottom is not loose or there would be water all over the floor))
  • Blow any water out of the air tube, it should be empty when the washer is empty, water remaining in the tube messes up the pressure sensing(usually makes water level lower so doubt this is the fault)
  • ensure wires are connected to control body.
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test whether just the adjustment is required,
  1. remove the water level knob from the front side of console
  2. depress the lock tab at the right side of water level sensor body where it contacts the back side of the console and rotate counter clockwise 45degrees
  3. withdraw water level sensor body
  4. adjacent to shaft for the knob is 1/8inch bolt head, turn clockwise to raise, counter clockwise to lower water level.
  5. washer can be operated with the console open and the level body removed just dont shock yourself on the cable connectors
  6. test, adjust, test adjust. (water level switch may need to be flicked hi-med & back to test adjustment
  7. if no effect replace water level sensor body
The water level switch body contains a small spring that is not really up to the job and stretches over years,
do this repair, on call, no parts, takes 15 minutes,, 3-4 times a month
Jul 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stackable water level
replace the water pressure switch it is non ajustable for insurance purposes
Apr 06, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
360 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
