Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
TV was unplugged for a little while and now won't power up and is making a buzzing sound. What can cause this?
    Scholar:
  • 67 Answers
How old is the tv? This is a power supply symptom. You will need to take the back of the tv off and check for puffed capacitors on the power pcb. This is the board where the power cord plugs into. Lay tv face down on a cushioned surface large enough to support the tv frame. You do not want to damage the panel. Then remove the back. If there are puffed capacitors, replace them with equal or slightly higher valued capacitors. The value rating for capacitors are mf and voltage, printed on the capacitors. If they look good, you will need to check the dc voltage output from the pcb usually about three connectors in the same area. One way or another, it is a power supply problem, usually corrected by replacing caps, but if that doesn't work, you will need to replace power pcb
Posted on Apr 03, 2011
Was working fine last night ,went to turn it on and you can hear a buzzing by where you plug in your jacks a bee,or high pitch sound.tv has no picture or sound.only sound you hear is this buzzing
Sounds like your power supply is causing the problem. Unplug the TV wait 10 minutes, look in the back for a red button (circuit breaker) push it in. If this does not work you have a low voltage power supply fault.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/reuben_09f18ea112b9b936
Mar 04, 2016 | Televison & Video
Westinghouse tv power box making buzzing sound
Hi I'm Peter, There is a bad connection and most likely the buzzing sound is a relay going bad internally.
Apr 19, 2014 | Westinghouse Televison & Video
I have a proscan 42LA45H 42 in television that has started making a buzzing noise from the back. What is causing this, and what do I need to do to fix.
Hi
If picture and sound is Ok, and only this buzzing sound is heard from the back of the TV, It should be due to core soose of some ferrite cored transformers inside, especially to the power supply regulator board of the TV. Open the back cover of the TV and swtich it ON. Listeen very carefully which transfromer makes the buzzing noise. Just trouch and press the core of the transformer suspected with some non-cunductive material like glass rod, or a stick of dry wood. You can identify the transformer that makes noise by this way. After identifying the exact transformer; switch OFF the set, unplug it from mains socket, apply some "Super Glue" like fast boanding glue to the joint of core of that transformer. Allow sometime for the glue to set. This will solve the buzzing sound problem of your TV. OK
Jul 13, 2011 | Proscan 42LA45H 42 in. LCD TV
Samsung plasma tv pn42a400c2dxza. when i try to turn it on it starts making clicking sound than it starts buzzing. i unpluged everything from the power supply and the buzzing sound stopped. but when i plug...
This problems is the power supply board is causes and the problems.Try website like Ebay.com buy a whole refurbish power supply board for the replacement,will solved this problems.
Nov 29, 2010 | Samsung PN42A400 42 in. Plasma TV
My TV won't come on, just makes a weird buzzing sound twice then shuts back off. Tried unplugging it, made no difference
there is nothing you can do,other than have a tech repair your tv.that buzzing sound comes from a leaking capacitor in the power circuit.or from the flyback.good luck.
Mar 01, 2010 | LG 42LC2D 42 in. LCD HDTV
TV Just Started Making a Humming/Buzzing sound
Replacing a flyback is not something I would suggest for anyone with no electronics experience. Second, lets see where the noise is coming from first. Take off the back and listen to the noise. The flyback will be at one end of the large red wires that go to the tubes. Sometimes the connection at the tube is not 100% and the noise comes from there. BE CAREFUL - there are high voltages going through this red wire that can be dangerous even with the set UNPLUGGED!! IF the noise is coming from the connection at the tube, with the set unplugged, carefully turn the rubber cap back and forth touching only the rubber part with one hand. Put the other hand in you pocket while doing this.
If the noise comes from the flyback side, if you can solder, again with the set unplugged, try resoldering the pins on the transformers. That may resolve the problem.
Keep me posted.
Dan
Feb 13, 2009 | Samsung HCL5515W 55" Rear Projection...
Quasar 1989 tv makes a buzzing motor sound
Hi and welcome to FixYa,
Initially, if you have confirmed that the source of the buzzing sound is from inside the TV, then that would indicate a component about to fail or would need attention. Let us try process of elimination:
  • tuner - most unlikely, the tuner is responsible for selecting the channel. No component/part of the tuner could make such a mechanical buzzing sound;
  • speaker(s) - most unlikely, the speaker could have a buzz but generally would not affect the video nor cause snow (weak TV signals);
  • transformer - a strong possibility although without knowing the exact model, at most generic ideas; power transformer, flyback transformer, horizontal drive transformer (unlikely);
  • arcing - another strong possibility. This could be caused by damp, dusty surroundings of the components especially at the FBT area. Another area that could have adverse effect when dusty/damp would be the anode cap.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 26, 2008 | Televison & Video
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
95 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
