Question about Gilmour 1 Gallon Lawn & Garden Spray Tank - 010pexg
I gallon spray doc how to open - Gilmour 1 Gallon Lawn & Garden Spray Tank - 010pexg
2 Suggested Answers
AndrexT
  • 14873 Answers
SOURCE: I need a manual for my Gilmour model 2000P spray doc garden innovation 2 - 2 1/2 gallon
That is just a simple pump sprayer. Your manual is here
Gilmour Professional 2000P Manuals
Posted on Mar 17, 2017
How much to use in a gallon of water
One Gallon of Cloud Cover makes up to 20 Gallons of diluted spray. Re-apply every 60 to 90 days for best result..
Oct 08, 2014 | Garden
Will not pressurize
Seals not sealing check cover rubber gasket and relief valve
Mar 05, 2014 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
Can I dilute Scotts Miracle Grow for use in my Ortho dial spray bottle?
Yes, you can use Miracle-Gro Water Soluable Plant Food in the Ortho Dial N Spray hose-end sprayer. Simply set the dial on the Dial N Spray to 4 ounces. The label rate for Miracle-Gro All Purpose Plant Food is 1 tablespoon per gallon of water. To make 8 gallons of finished spray, measure 8 rounded tablespoons of plant food into the Dial N Spray jar and fill the jar with water. Mix thoroughly. Set the dial at 4 ounces. When you have sprayed until jar is empty, you will have applied 8 gallons of properly diluted spray. Hilary@Scotts
Jul 23, 2011 | Garden
What setting do I use on my ortho dial and spray for fertilizing plants and vegetables outdoors? Thanks
If you are using Miracle-Gro Water Soluable All Purpose Plant Food in the Ortho Dial N Spray Hose End Sprayer, follow the directions below :
  • Set the dial to 4 oz
  • The sprayer can make up to 8 gallons of spray. Add the correct amount of product to the jar for number of gallons you wish to make. (Example - The dilution rate is 1 tablespoon per gallon, and you want to make 8 gallons, put 8 tablespoons of Miracle-Gro Plant Food in the jar.)
  • Multipy 4 by the number of gallons you are making and fill to that oz line (Example - If you are making 8 gallons, 4x8=32 so fill to the 32 oz mark with water).
  • Prior to spraying, mix product around in the jar until granules are dissloved.
  • Spray until the jar is empty.When it is empty, you have sprayed 8 gallons of product.
If you any questions or if you are using another product, please give us a call at 800-225-2883, and we will be happy to figure out a setting for you!
Jul 05, 2011 | Garden
Water leaks out of the bottom
If you see water leaking it might be that the plastic has a broken, try to seal it with super crazy glue.
Thanks
Jul 01, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
It will not spray
Your pump cam follower may be broken, such that the pump is just not working. Good news, you don't need to buy any new parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmour provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business. Since the higher the wheel speed the more stress there is on these tabs, I would not recommend moving the wheels any faster than what occurs with a slow walk.
See photos at:
http://s911.photobucket.com/albums/ac317/vonoretn/Gilmore%20Wheelpump%20sprayer/
Jun 04, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
My gilmour wheelpump sprayer just quit spraying. It appears to not be building up pressure. I have cleaned out the valve and screen on the bottom, removed and rinsed out the hollow oval 'ball'...
Your pump cam follower may be broken, such that the pump is just not working. It happened on mine. You don't need to buy any parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmore provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business.
See photos at:
May 11, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
I have a 3-gallon gilmour sprayer--has worked well-only several month old-able to get good compression but can not get anyspray-even after taking apart and rinsing your help is appreciated thanks ...
This situation sounds like a plugged hose. Keep taking apart and you will find something plugging a small orifice, somewhere... Always flush with clean water after each use, many garden sprays crystalize over time......
Apr 24, 2011 | Gilmour & Spray Doc& Poly Tank Sprayer...
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Gilmour 1 Gallon Lawn & Garden Spray Tank - 010pexg Logo
117 people viewed this question
Top Gilmour Garden Experts
Mike
Andrew Taylor
Andrew Taylor
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
