I want to hook up a old stero amp and some 3 way speakers for my old dell4500 ifigure that would proably b the cheapest way to get the most bang for my buck. i would really like to have a surround sound but cant afford. what would it take for me to hook up amp& 3way to my dell4500
  • 492 Answers
Use the stereo output on the sound card and a 13mm adapter to RCA inputs on the amplifier. I think they still sell these at Radio Shack.
Posted on Apr 03, 2011
Tuner on stero works fine, but will not play CD or USB do not produce sound. When CD or USB is in use, the displays shows that the cd or usb is playing. But no sound comes out of the speakers. I returned...
It sounds like you have some wiring issues, moreso issues with your speaker wiring, or your speakers. I would first test the speakers, 1 by 1 using a double A, or AA 1.5v battery. Each speaker wire pair should be tested by attaching 1 wire to the negative side of the batter, and momentarily making contact with the other wire to the positive side of the battery. A low popping/scratching sound should be heard from each speaker. If not, replace each defective unit. Also, double check your wires to ensure they are not damaged.
Jan 19, 2011 | Sony CDX-GT550UI
I have a 5.1 speaker setup. i have a 5.1 sony dvd amp. a ps3 and a old toshiba tv. ( the one with the orange white red plug in the back. i wanna hook up 3 speakers for front and the subwofer. how do i do...
So, you don't want to use the TV speakers, right? Hook your PS3 audio output RCA jacks to the input on the amplifier and hook the PS3 video cabe to the yellow (orange) video input of the TV. Then hook your speakers to the front or rear outputs of the amp and the sub to the sub output of the amp. If you want to use your TV speakers, you can connect them to the front or back output of the amp for a 4.1 setup. OK?
Dec 09, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
I HAVE A AMP AND SUB HOOKED UP 2 MY KENWOOD STERO, HOW CAN I INSTALL IT THE RIGHT WAY SO THAT IT WLL TURN OFF WITH THE CAR?????
If your radio shuts off with the key and you use the power ant. or the amp turn on wire for your amp when your radio shuts off so will your amps. If your radio is wired constant hot you need to change the red wire on your radio to a key hot.
Aug 20, 2010 | Car Audio & Video
Information on the 12'' Thump subwoofers TH-1232
The are precision audio subs. Very old brand that isn't on the market anymore. I have one of their amps from proably 1994.
May 21, 2010 | Car Audio & Video
Had dead battery in 2002 honda civic got jump now word CODE in radio display
try disconecting the positive terminal of the batery for sevral minets (5-10) this will reset the brain box memory for the stero aswell as for the car it self.
what caused the batery to go dead in the first place?
things that i can think of :
1) left headlights on over night
2) bad altenator not charging batery
3) battery is old and not taking a charge anymore
4) new stero installed incorectly and drainging the batery
have you resently installed a new stero or amplifyer?
is the turn key igntion system hooked into the amp/stero antena lead so that thy are shut of when the ignition is?
of note: new streo >theres a blue wire marked ant that goes to the amplifyer if not there you need to find the orange accsesory wire coming from the turn key igntion>check for power when ignition is in the on & off states could be yellow in some cars but is usaly orange if this wire has on and of state controled by the turn key igntion this would be the wire to tap into for the amplyfire and the radio main power
check your radio's instaltion guide for code errors
its posible that when hooking up the jump it was done incorectly and blew up the radio
ie postive and negative where fliped
hope this helped :)
Feb 24, 2010 | 2002 Honda Civic
I hooked up a car sterio and everything works but there is no sound. Is it possible I have a + and - crossed on one of the speakers? I am pretty sure everything on the deck is hooked up right because i had...
some cars come with a built in amp that is probably located in the rear of the car and the only you can put in an after market stero is to bypass that amp so that means that you would have to run new speaker wires to all the speakers.
Dec 28, 2009 | 2000 Chrysler Cirrus
How to hook up a subwoofer to my computer?
i to have that sub and i hook it up to my dell 1501 i use a mini steroe plug it has two input so you can hook up two device get two y cables on one end it will have a plug like your headphone plug on the other end has two male the ones you hook up at the back of your steroe the other cable is a y cable as well this one has two female end and steroe end to hook up to the sub connect both wires to become one male to female one end goes to the computer the other end the sub you cant do it wrong there is only one plug that will fit hope this helps .
Jan 12, 2009 | Jensen JW250 Main / Stereo Speaker
Confused need help!!!
i need the watt of da stero DC-Z92
Oct 31, 2008 | Insignia 3-Way Indoor/Outdoor Speakers...
Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
187 people viewed this question
 Grubhead
Grubhead
