Question about Maytag Dryers
Maytag Perorma Dryer Model PYE10000 having probelm with the motor make nosie it sound like the motor is going out. and it sto turning, pls help. not use if need to get parts to fix motor are where is th troubleshot coming from. demetriareece@yahoo.com
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 03, 2011
Maytag neptune Model # mdg5500 AWW when i push
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer model PYE2300AYW dryer runs gets hot stops. when I try to turn it back on it makes a noise and won't start back up. What could be wrong?
It sounds like your motor is bad. you could take the dryer apart and clean off the lint on the motor and see if that helps but it sounds like i said the motor is faulty.
Mar 24, 2010 | Maytag PYE2300AY Electric Dryer
My Maytag dryer (model # MDE4806AYW) makes a grinding sound all of the sudden. Sounds like the cylinder drum is scraping on something. The dryer is only a couple of years old. What do you think needs to be...
Could be your front glides on your drum housing. They are just Teflon pads that the front of the drum rides on. If they wear down you will get a metal on metal rubbing. The part number is 40116501. The other possibility could be your rear rollers going bad but they usually will make almost a squeak usually. They are what support the rear end of the drum.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Dryers
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Dryer will only dry clothes half way, then when i go to continue drying,dryer will not turn back on until cooled down
Hi, the motor is overheating. i recommend inspecting the motor windings for splits or separation within the strands. make sure all wire connectors to the motor are not corroded or lose. replace the motor if there are signs of windings failures or discolored copper strands.
May 28, 2009 | Maytag Dryers
Maytag performa dryer
You may have a bad motor that turns the drum. Have it checked out. Does your breaker trip when it stops running? Last I would check is the timer of the dryer.
Jan 24, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dyer MDE9206AYW
moter bad
start switch wont ingage
Jun 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
