Question about Verizon Communications Ethernet/Wireless-G Gateway DSL Starter Kit for
Internet connection my internet connection is bad, becuz there are 3 bars that must stay constant green on this modem/router. 1. the power. (obviously works) 2. dsl (obviosuly works) 3. internet...now this one turns off and on and it disconnects me from my messaging with other people. i dont know why this happens but ive tried taking out the filter to my wall jack and its still the same. and right now the internet light turned off again. is it bad connection? should i change to a different provider? and i dont know who to call so plz help me out thanks guys
    Genius:
  • 1,605 Answers
Connection is OK, try to move the router or the computer close. till you have a good connection. then start move away, till you start to have problem. that is the max distance you can go away from the router.
Posted on Feb 04, 2009
Unable to connect to the internet
possible reasons why you can't connect to the internet
1. Ethernet cable is not plug in tight from the modem to your laptop. 2. DSL light on your modem is RED/flashing green/ OFF 3. if you have router try to unplug both modem and router for 20 seconds then turn your modem on first and wait for the DSL light on the modem become solid green before powering the router ON 4. check the LACAL AREA CONNECTION. it might be disabled. to check click satart menu then go to control panel then look for network ana internet then click network and sharing center. From the left had side of the page look for manage network connection and click it then check if the LAN is disabled. if its disabled right click the LAN and select enable. 5. check internet connection again if it works
Sep 10, 2011 | Computers & Internet
Tip
BellSouth AT&T Motorola Modem Red Light/s, No Internet
Modem, Router and PC
1. Press and hold the reset button on the back of your modem for 10 seconds to fully reset your modem to initial factory defaults.
2. Wait for the modem's Power and DSL LEDs to turn solid green.
3. Open your computer's Internet browser and your modem should launch a mini-setup routine. Enter your FastAccess DSL username in the format of yourusername@bellsouth.net, enter your FastAccess DSL password and confirm your FastAccess DSL password and click next, then there will be an "Auto Calender Update Configuration" page where you will set the auto update info and timezone info so just enter the info and click next.
4. Your browser will refresh the page and say everything is ready to go, this may take a few moments. When this is complete type 192.168.1.254 into your browser's address bar and click on the "Broadband DSL Line" tab, then on the right, click on Connection configuration.
5. Change the Protocol from the dropdown box to Bridged Ethernet Mode, and then click on Save and Restart Connection.
6. Open your computer's Internet browser again and type in 192.168.1.1 into your browser’s address bar. In the Internet Setup, change the Internet Connection Type to PPPoE and enter your FastAccess DSL username in the format of yourusername@bellsouth.net, enter your FastAccess DSL password and click on Save Settings.
7. Close all windows and restart your computer. Your internet should now be working.
Modem and PC
on Jul 24, 2010 | Computers & Internet
I'm trying to connect a D-link DIR-615 router to my inlaws computer. They have an old motorola external modem which works fine, the new router is connected properly to the power suppy, ethernet cable from...
You haven't mentioned who is your Internet Service Provider (generally motorola modems are used by cable connections). After connecting the cables properly, you power cycle the modem and the router if this is a cable connection. However, if this is a DSL connection you better contact the ISP and fetch further information. Please contact me again if you need further information.
Apr 24, 2011 | D-Link DIR-615 Wireless Router
I have a netgear range max, it has been working fine. Just last night nothing wireless in my house works. Cable modem works. Power light on netgear box is green. "i" icon is flashing green,...
You need to reset and reconfigure router
please follow the steps to reconfigure router
RESET THE ROUTER:
1. Make sure router is connected to power supply and is on while you perform the task below. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing. Turn off the router and turn it back on after a couple of minutes.
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Regards,
Prakash
Apr 08, 2011 | NetGear WGT624 Wireless Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I have a new modem from comcast and now my router will not connect to the internet. i have reset the router and even connected directly to the router to see if i can get internet and still can not get...
    To restore the router to factory default settings, please do the following:
    1. Unplug the router's power supply
    2. Press and hold the reset button on the bottom of the router
    3. Keep the reset button depressed and, at the same time, plug the power supply back in
    4. Keep the reset button depressed for another 10 seconds
    5. Release the reset button
    ======================= Manually configuration ==============================
    ISP Cable or Dynamic
    Step 1 : Connect modem - Router - Computer ( Wired )
    Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
    Step 3 : On the left side under internet WAN click Connection Type
    Step 4 : leave the Password Blank and click submit
    Step 5 : Choose the connection type as dynamic and click next
    Step 6 : Leave the Host name blank and click apply
    Step 7 : On the left Under Internet WAN Click MAC Address
    Step 8 : Click Clone and Click Apply changes
    Step 9: ISP DSL
    Note: If your connection is DSL choose the connection type as PPOE
    and set your User name and Password( ask yous ISP provider
    Step 10 : Then check if you have internet
    Step 11 : if not Then unplug the Power Cable from the Modem And the Router
    Step 12 : Plug the power Cord to the Modem
    Step 13 : Wait till all the lights are on
    Step 14 : Plug the power to the belkin
    Step 15 : Check the color of the light in the belkin
    Step 16 :If green then Check if you have internet
    If not working then call belkin
    ========= WIRELESS SETTING UP A WIRELESS CONNECTION ====================
    Step 1 : Connect Router - Computer ( Wired)
    Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
    Step 3 : On the left under wireless click wi - fi protected setup
    Step 4 : Leave the password blank and click on submit
    Step 5 : Disable it and Click on apply changes
    Step 6 : On the left under wireless click Security
    Step 7 : Enable 64 Bit WEP
    Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
    Step 9 : Click apply changes
    Step 10 : on the left under wireless click channel and SSID
    Step 11 :Change the Wireless channel to 6
    Step 12 : Change the SSID to a different name ( no Spaces )
    Step 13 : Click apply changes
    Step 14 : Now Scan and connect to this network ( Wireless )
    Let me know if it works
    May 27, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
    My linksys WRT150N router won't recieve internet signal from my dsl modem. The router sends out a signal to my lap top, but no internet connection can be made.
    Try connecting your laptop directly to the dsl modem to make sure that it is working correctly.
    If the dsl modem is working correctly then:
    1. Turn off the power on the router and dsl modem.
    2. After about 2 minutes, turn on the dsl modem.
    3. Wait another 2 minutes, then turn on the router.
    Occasionally you need to do this to get them back in synch. If this doesn't work you may need to use the software utility to reconfigure the router.
    Dec 27, 2009 | Linksys Wireless-N WRT150N Router
    Can't connect to internet when router is connected.
    You might try this:
    1 power off or unplug your cable or DSL Modem.
    2 Power off your router
    3 waiti about 30 seconds,
    4 plug in your cable/DSL modem
    5 wait until the modem boots up (all lights except activity should be on)
    6 power up your router.
    Did that work?
    Apr 05, 2009 | Belkin (F5D7230-4) Router (VVLZ253558)
    My internet connection is bad, becuz there are 3 bars that must stay constant green on this modem/router. 1. the power. (obviously works) 2. dsl (obviosuly works) 3. internet...now this one turns off and...
    This is obviously a faulty modem/router. You may either request a new modem from your provider or if the service is not that good, you may consider other Internet providers.
    Aug 05, 2008 | Verizon Communications Ethernet/Wireless-G...
    Verizon Communications Ethernet/Wireless-G Gateway DSL Starter Kit for Logo
    76 people viewed this question
    Top Verizon Communications Computers & Internet Experts
    David Payne
    David Payne
    Are you a Verizon Communications Computer and Internet Expert? Answer questions, earn points and help others
