I have error f05 come up and now a drum full of water - how do I drain this and get the door open to empty and clean the filter? Believe it could be jammed pressure switch or blockage so need to know where to locate Thanks
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
F-05 usually relates to either the pump being blocked or the sump of this particular model being full of coins, color catchers etc.
first keep it simple, ensure outlet hose is not blocked or kinked....but if not follow these steps
  • To sort this isolate from mains
  • take off back inspection panel.
  • tilt machine forward- get sum1 to hold it for u.
  • The sump is the black hose attached to drum.
  • place a basin under this and loosen jublie clamp using star head screw driver/ 8mm socket,
  • pull sump downwards and remove any blockage.
  • note the plastic ball is part of the sump assembley.
  • refitt the sump again and tighten clamp, pull down firmly on sump to ensure fitted correctly
if there was nothing in the sump it is sumthing jamming the pump, hairgrip, nail, etc.
tilt machine forward as above with a basin ensuring isolated from mains power
  • pump is attached to other end of sump hose, right side of machine as you look in the back.
  • using flat screwdriver lift plastic tag up and slide pump assembley to the left releasing it from base of machine
  • clip of plastic cover from top of pump
  • remove wires from pump
  • u should now be able to turn pump around so u can see 3 hex head screws
  • remove screws taking note of the position of pump
  • remove pump and clear blockage
  • reverse steps to reassemble
if this does not sort it poss a new pump needed.
Posted on Apr 03, 2011
Wf 860 error code f05 psi switch jammed on full - machine had not emptied water. Is this faulty switch or blocked pump etc?
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Check for blockage first.
Feb 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMF720p - getting message F05 can you help? Water trickling out when draining and error message F05 appears inbetween all cycles.
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Please rate my solution.
Thankyou.t.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint machine has filled with water and won't empty error F-05 FLASHING before that all lights were flashing ??
Error F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Fit back and test
Jan 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Error code F05 indicates pressure switch jammed on full.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius+ washing machine won't drain and got an F05 error code when trying a wash cycle. Initially the inlet pipes had frozen due to the cold weather but it is now taking in water. However it...
Error code F05 means pressure switch jammed on full.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum
Remove and clean filter in side hose.
This should solve the problem
Thankyou.
Jan 13, 2010 | Hotpoint Aquarius WD640 Front Load...
Fault code F05 on an indesit washing machine WIXE 167.it not emptying the water
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove large black fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Hop[e this helps you.
Dec 28, 2009 | Washing Machines
Error code E20 on Zanuzzi washing machine. Not draining/washing.
Simple in most cases its just the filter outlet has becopme full of day to day junk, debris and slime.
Slowly release the water by turning the handle to release the water. Ensure power is off.
Once water has been drained into a shallow tray you will be able to open the door.
Once the drum is empty, unscrew the handle completely to remove filter housing an clean out thoroughly.
replace and tighten up.
Turn on power and reset all programmes.
this should work, total cost about 15 minutes of your time.
If it doesnt work it may then be your pump, time to think about and engineer
Nov 29, 2009 | Washing Machines
Cycle does not finish door wont open error code f05
F05 means pressure/\waterl level switch is jammed on full.
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum.
Remove hose onto pump, and check for obstruction here and in the pump.
Please leave feed back
Thanks
Nov 12, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint wdd960 washer dryer error f05
f05 means blockage and cannot drain-switch off at mains to reset error-turn to drain if pump runs but dont drain filter in sump blocked/if no pump action then somthing is jammed inn pump
Nov 08, 2009 | Washing Machines
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
