Question about Refrigerators
Maytag Model MTB2156FE* Challenge: how to limit the range of door opening. Currently opens full and is damaging nearby furniture. Would like to have it open without swinging widely. Thanks
  • 161 Answers
SOURCE: GE Side by Side Fridge Door Adjustment
Most refrigerators do not have anything to prevent the door from opening all the way. To minimize this , adjust the front leveling legs up enough so the door won't stay open by itself. The refrigerator doesn't have to be level, it just should not rock. Most are adjusted this way to let the door shut itself. This should help. If this doesn't work. make a strap with small chain or seat belt type material. Attach from the bottom of the door. Make it just long enough to not let the door open past 90 degrees.
Posted on Jul 03, 2008
sdmc73
  • 121 Answers
SOURCE: French door on right keeps swinging open
yhe leveling of the unit will help
Posted on Nov 29, 2008
dragonsthatk
  • 547 Answers
SOURCE: Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Posted on Feb 11, 2009
Healeyman
  • 1198 Answers
SOURCE: right side door keeps on swinging open
Does it have a magnetic gasket? If that has cracked and failed, it's not too hard to replace. If the door is warped out of shape, just push it back.
Posted on Apr 27, 2009
Muzzi_123
  • 749 Answers
SOURCE: Refrigerator Door Does not Close Properly
Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
Posted on May 14, 2009
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Jul 06, 2016 | Maytag Kitchen Ranges
I have a Clicker universal Garage door opener remote control Model KLIK1U. How can I increase the range to open the door? Currently, I have to be within 10-15 feet of the door opener to operate. I have...
Check the antenna on the motor. It is usually a single thin wire. There also could be something nearby that is causing interference to the unit and it wont pick up the signal till the transmitter is close enough to overpower the interference.
Oct 28, 2013 | Building Materials
Unlock door of maytag range model mgr7775ws
unplug the range let it sit for a while then plug it back in.
Oct 23, 2012 | Maytag MGR7775WS - 30"Self-Cleaning...
Where is the model number/ serial number located on the Maytag Gemini?
Open the door and look at the very bottom, front of range. If yours have a drawer it will be located behind the drawer right under the bake door, on the oven frame.
Jan 05, 2010 | Maytag Gemini 30" Self-Cleaning...
Door will not open
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "door will not open".
Nov 24, 2009 | Maytag 2.0 Cu. Ft. Over-the-Range...
Maytag over the top microwave keypad some keys are dead
You have a failing membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open.
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So please reply back directly to me with your brand and full model number from the tag in or on the unit for more help or free do-it-yourself tips or an estimate if required.
We're happy to help you with free advice and once we have given you our final answer, we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 26, 2009 | Maytag 2.0 Cu. Ft. Over-the-Range...
How to install Maytag oven door for model MGR5765QDQ ?
Pull the door mount bars to the first stop--where you keep the door open to broil. Slide the door back down on the bars.
Mar 02, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Open the door when broiling?
Maytag does reccomend leaving the door open to first stop when broiling in the gemini range.
Jan 15, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Craftsman GDO, Model 139.53600. moves 4inches up/ down
Find the increase travel adjustment screw and turn it clockwise 1/4 to 1/2 turn.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can the way the door opens be switched??
no no door lock switch monunting on the other side
a maytag dryer can
Apr 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
