Question about Whirlpool Dryers
Whirlpool condenser dryer not working. Power coming in to machine but that is about it.
    Scholar:
  • 97 Answers
Hiya
does the machine make a buzzing noise? or heat up?
if it makes a buzzing noise and heats up it will more than likely be the motor surpressor, all this does is gives the motor a kick start to set it off tumbling with a wet load. theres a quick way you can check if it is this at fault, make sure the drum is empty and set timer as you would normally, open the door and spin the drum as hard as you can then shut the door quickly (whilst drum is still turning if you can), the dryer should now run normally until it stops again.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 05, 2008
Where is cut off switch on whirlpool condenser dryer
Typically on condenser styles there is a hi limit thermostat on the element housing.
Feb 01, 2015 | Whirlpool Dryers
Whirlpool awz 8578
sounds like your vent is the problem.hope this helps.
Jan 28, 2018 | Dryers
Bosch condenser dryer
The first thing that you need to check is the door switch.
Jul 23, 2013 | Dryers
WHIRLPOOL AWZ8577 somehow my dryer is getting the water out through the little tube at the bottom of the back. I want to know how to make the machine collect the condense water into the container again...
whirlpool awz8677 i am getting the same problem with my brand new dryer. Getting water coming out through the bottom front and back. Anybody know how to solve this problem? Thanks.
Oct 23, 2010 | Dryers
Whirlpool condensed tumbler dryer
check ur dryer vent in the back u might have pushed it back too far and kinked the hose ar u might have a buildup of lint in the dryer vent pull the dryer out and take the dryer vent off and run a load of clothes like this if it works look for a lint buildup in the hose or u just had the hose kinked
Feb 26, 2010 | Whirlpool LER5636P Electric Dryer
No power to Whirlpool Condenser Dryer AWZ7813
check your wall plug it could have went out
Jan 29, 2010 | Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Jul 09, 2008 | Dryers
Dryers Logo
136 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
