Question about Sharp 25N-M100 25" TV
Audio Levels are a mess??
I have the levels on my Sharp TV all the way up to 50 and can barely hear a thing...ive tried unplugging and resetting and unpugging even the dvd player....usually at 32 this tv is very much loud enough.
any solutions? ive even read the manual...
  • 1 more comment
  • joanac84 Aug 05, 2008
    ask crazy as this may sound...i dont have a headphone jack on the tv??? just cable ones???
    oh and i just also noticed that im under the wrong model forum,,, oops
  • Anonymous Feb 11, 2009
    my sharp aquos volume will only go up to do I change it?
  • 101 Answers
Connect a pair of headphones to your telly and see if the sounds is correct at all volume levels.
This will at least tell if you if it is the audio processing or simply the speaker/amplifier section
Posted on Aug 05, 2008
The volume on my sharp--lc19SB25U is barely loud enough to hear. I have other tvs and don't have a problem hearing them. can this problem be solved.
Tries tv unplug,replug it back like about an hour later to let the tv resetting itself back to the factory setting.Go into Menu go to AUDIO Setting go down to reset back to the original setting.If this dosen't help the whole tv Tuner signal board is the causes and the problems.Tries websites like, to buy a whloe refurbish tv Tuner signal board for the replacement.
Dec 17, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
I cant hear the tv
Hello drive2darim,
OK first check you converter box, Cable TV/ Satellite TV volume control and turn it up to 100%.
Then check the menu on your TV for audio settings and set them to there default settings. This should take care of this issue.
I hope this helps,
Thank you,
Jul 13, 2009 | Emerson Televison & Video
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
I have RT2280. Audio levels used to be 1-50, now
Sounds to me as if someone may have gotten into the menu to adjust the individual levels of each loudspeaker and cranked some of them way up. As to why the "main" volume level goes from1-20 now as apposed to 1-50, you got me there...
Is there a reset button or equivalent on the remote or the unit? Try that. Try unplugging the unit for 15 minutes...
Here's the owner's manual:
See page 21 for advanced volume control functions...
Mar 04, 2009 | RCA RT2280 System
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
Feb 02, 2018 | Yamaha RX-V596 Receiver
Audio volume level
Hi, I'm guessing your turning up the volume on the TV box to control the volume of your speakers. By doing this your only controling the audio strength coming out from the TV box.
What you should be doing is turning up the volume on your TV or amp feeding your speakers rather than the direrct TV box. The level of the speakers may have been reduced form last week (other people messing about with your equipment?) which is the reason why you have to turn it up to 30 rather than 10.
Another problem could be a loose audio connection from you direct TV box to your amp or TV. Have you tried a different source such as a DVD player, and does the sound on that seem alot quiter than before? If the volume of this is alot quiter also it could be a problem with your speakers.
Hope this helps.
Nov 01, 2008 | Televison & Video
Sound issues?
Yeah, your remote has a volume control under the audio button, turn it up.  --Bob---
Aug 05, 2008 | Philips DVP3960
No sound from my sharp aqous 37d4u. The sound was on, turned the tv off, turned it back on later and nothing. Unplugged it, reset it. still no sound.
Good Day;
You stated you have no sound after turning the TV off, and had reset it & still no sound. Well you did the right thing, but are you using a cable or sat. box? If so did you reset those or make those 'boxes' volume's were not turned down.
After resetting the entire system and checking for volume levels it sounds like the LCD may have a defective A/V (audio/ video) board that is really easy to replace. 90% of your audio circuit is on that board.
Good Luck; Big I.
Jun 17, 2008 | Sharp Televison & Video
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp 25N-M100 25" TV Logo
108 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
