Question about Whirlpool Microwave Ovens
What is the bolt size for the over the range whirlpool microwave top holding bolts?
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-1450 micro over range removal
Those specific installation instructions are no longer available, but I have a couple for other models that may be close enough to help.
I have uploaded them here and here.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 21, 2008
  • 13 Answers
SOURCE: One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Posted on Dec 31, 2008
  • 52 Answers
SOURCE: Recommended clearance from bottom of microwave to range top
Your installation manual should have given specific height limitations. I'm not sure for your model, but I beleive it's no less than 22". If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 29, 2009
SOURCE: What size of bolts are needed to mount a GE
1/4 inch
Posted on Jan 12, 2010
Remove microwave built in range
I) empty the cabinet above the unit.
2) unplug the unit from the outlet in the cabinet
3) locate the two bolts near the front edge in the floor of the cabinet and remove them. the unit will tip down to the range below.
CAUTION SUPPORT THE UNIT WHILE TAKING OUT THE BOLTS OR THE UNIT WILL CRASH
4) Two people can then lift the unit from the support on the wall.
Aug 22, 2014 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Removing the cover on a Whirlpool Microwave Model MA1170XSS-0
You may find it has security type bolts that require a special bit, take a good look to see what the bolts that secure the cover look like.
Nov 05, 2012 | Whirlpool Microwave Ovens
HOW TO REMOVE A MICROWAVE
I assume you are talking about an "over the range" microwave.There should be 2-3 bolts holding it in from the cabinet above.You probably should have a second person to help.Remove the bolts while holding it up,when the last bolt is removed,lower the front,then lift the rear of the microwave to release it from the wall bracket.
Jul 06, 2012 | Amana Microwave Ovens
How to uninstall a Whirlpool microwave Hood Combination? Model MH6600XV
Unplug the range and move it out of the way.
Open the cabinet above the microwave.
Unplug the power cord.
Remove the 2 bolts going through the cabinet into the top of the microwave.
Have a helper hold the microwave in place before these bolts are removed.
After the bolts are out,assist the helper by lowering the front of the MW and lift the back of it off the mounting bracket attached to the wall.
They are heavy and awkward.
A helper must be used.
Jan 21, 2011 | Microwave Ovens
I cant uninstall my whirlpool microwave
The mounting bolts are usually inside the cabinet on top of the microwave. They are usually allen screws or star screws.
Jan 01, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
I have a whirlpool cabinet mount microwave model gh5176xpq-0 I need to remove from the cabinet. I have removed the top mounting bolts but there seems to be something else holding it.
IS THERE A PLATE HOOKED TO THE WALL IT IS RESTING ON. TRY PUSHING UP THEN OUT. IF THERE IS A CABINET ABOVE IT YOU MAY HAVE TO LOOSEN IT ALSO
Mar 06, 2010 | Whirlpool Microwave Ovens
I need to uninstall my whirlpool model mh7130xeq1 what is the best way to do this and do I need two people?
I'll assume this is over the range. If uninstalling alone please move the range out of the way. Pad the floor nearby to have a place to put it down when it comes off the wall. Be careful of the floor when moving it. Empty the microwave compartment. There should be 2 bolts or screws through the bottom of the upper cabinet that thread into the top of the microwave, these support the front and a back plate that is fastened to the wall that supports the back. Unplug the unit loosen the front support bolts, be ready when they release you'll catch about 50-60 pounds on the front. Tilt the front down and pull the cord out of the bottom of the cabinet. Grasp the microwave with both hands keep it tilted down in the front and lift the back slightly to remove it from the back plate. Set it down on the padding and celebrate success. Good luck. Yes one person can safely remove the microwave.
I found these instructions at Whirlpool they may help. Different model, same concept. Take link for instructions.
http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/WMH2205XVS_Installation%20Instruction_EN.pdf
Dec 03, 2009 | Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How to remove from wall for remodel project
There are 4 bolts or should be 4 holding the microwave top to the cabinet. Open the doors to the upper cabinets and you should see the bolt heads unplug the microwave unscrew the bolts while holding the microwave. After the bolts are out tilt microwave towards you and pick up from the bottom next to the wall to remove oven from mounting plate and thats it.
Sep 16, 2009 | Sharp R-1505 Microwave Oven
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Microwave Ovens Logo
159 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
