When I turn it off, the power indicater light stays on. It won't come back on until I unplug it all together and plug it back up.
    Scholar:
  • 67 Answers
Can you send me the make and model? Is there a backIight when you power on the tv? It sounds like a power supply problem. You will need to take the back off and check the power supply for puffed capacitors. Lay tv onto table with a blanket on the table. Place if face down and make sure the table is wide and long enough to support the frame. You want to support it by the frame so that the panel doesn't get damaged. If there are puffed caps, you will want to replace them with equal or slightly higher valued capacitors. They capacitor values are microfarad and voltage, which is printed on the capacitor. The power pcb is the board where the line cord plugs in. If this doesn't fix the problem, you will need to check the voltages with a multimeter printed on the power pcb next to the connectors going out of the board to see if they are correct. If they are it is probably a main board issue, Tcon, or panel issue.
Posted on Apr 03, 2011
  • 23 Answers
Hello, there is a problem with the PSU (Power Supply Unit) check it.
Vizio m320sl "no power" but will stay on if I don't turn it off
The internal power supply is failing. It keeps trying to start over and over again but only succeeds occasionally.
Dec 11, 2013 | Vizio Televison & Video
Screen won't turn on/Power stays on
To do a power reset, unplug your laptop, remove the battery and hold the power switch down for 30 seconds.
otherwise it may be problem with your screen back light...
Apr 10, 2013 | HP G60-535 Laptop Notebook Netbook...
It won 't turn on
check your power cords, check your outlets, check your surge protector, check the switch on the back of the pc. there may be a black toggle switch with a circle and a line, make sure it's flipped to the line side. if all that is normal, unplug the cord from the computer and open up the case. look at all your power plugs and make sure they're all secure, try and reseat the 1 or 2 main plugs, there should be a rectangular 12 pin plug and maybe a 4 pin plug. unplug them and then plug them back in. put the case back together plug it in, and give it a go. if still nothing then you have to troubleshoot whether the power supply is junk or if your motherboard died. we'll move on to that if it comes up. good luck!
Jan 30, 2012 | Gateway 300 X PC Desktop
Won't turn on..I have checked all the connections to the power source but still nothing
Unplug the power cord from the wall and the wii for 5 minutes. Then plug all back together. You just need to reset the power block.
Oct 12, 2011 | Nintendo Wii Console
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Sep 12, 2011 | LG WM2501H Front Load Stacked Washer/...
Three red lights and no power
Did you let it heat up untill you get the 2 red rings. If not unplug your fan; turn it on and wait untill you get lights 1 and 3 flashing. turn it off and wait a couple of min. then plug your fan in and add the wind tunnel. then turn it back on. If it still doesn't work you did the X-clamp fix wrong.
Jun 28, 2009 | Microsoft Xbox 360 Console
All lights stay on solid, cannot get lights to reset, and printer won't turn off unless unplugged. When plugged back in it goes to the same state. Printer cartridge holder doesn't move to the loading
sir try to put your printer to factory settigs by pressing the "start" & "cancel" button together & while holding these buttons together,try unplugging & replugging the printer power chord 4-5 times from the back panel of the printer....
Apr 26, 2009 | Office Equipment & Supplies
RCA Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. If you push the menu button after awhile the red light will stay on and not blink....
Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. Eventually the red indicator light stays red. Tried unpluging set. Is it the EPROM ?
Jan 19, 2008 | Televison & Video
Reset the water filter indicater light
hold light and lock buttons until lamp blinking release and lamp turns off no it is reset.
Jan 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Televison & Video Logo
Top Televison & Video Experts
