Question about HP w17e Monitor
My hp monitor giving an error mesage: attention input not supported. I have HP pavilion PC & HP w17e monitor. When I start on safemode it display normal. I receive the above when I start the pc on normal mode. Regards Durai
  • 23 Answers
Hello, when you enter safe mode change the resolution of your computer graphic card to: 1024x768 and it will work!
success!
Posted on Apr 03, 2011
My HP w17e monitor is going into auto configuratation all the time on its own. It happens at random. How can i corrcet this problem
If you are handy as far as electronics go you can replace the main board here is an example
http://cgi.ebay.com/HP-Digital-Video-PCB-F1703-Monitor-715L1006-/120755098558?pt=LH_DefaultDomain_0&hash=item1c1d9093be#ht_500wt_901
otherwise you need to send it to a tech. Email me from my ad and I will do it for you if you'd like
Jul 28, 2011 | HP Pavilion F1703 17" LCD Monitor
I have a attention input not supported recanagle that continually scrolls around and around my screen and i cannot acces the menu or do anything. I disconnected it from my modem and then from the monitor...
This is most likely because your computer is trying to display a screen resolution higher then tht monitor can support. Turn your PC on, and press F8 until you see a black and white menu. Select safe mode. Run safe mode and when windows loads, goto your control panel. Select Display and navigate to the resolution / settings tab. The screen resolution should be set to 1440 x 900 for this monitor to display video correctly.
If you need more detailed information on where to find the display resolution settings in windows I will need the name of the OS you are running... XP, Vista, Win 7 etc..
Regards, Chris
Jul 01, 2011 | HP w17e Monitor
It was working fine yesterday. Today is states VGA no signal. What is the problem.
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 17, 2010 | HP w17e Monitor
My hp w17e will only work for about 5-7 seconds when I first turn it on, and then goes blank. If I turn it off and back on again, the same thing happens. Is it fixable?
You should do some research here first: www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ It's an old blog, but could offer a solution worth exploring. Just remember to rate this response after you do your research there. 12fixlouie
Sep 25, 2010 | HP w17e Monitor
W17e Monitor: Is there aLinux driver for the HPw17e monitor?...
Hi, unfortunately compatible driver for this flat panel monitor for Linux is not available in the HP site hence it is not available.
May 18, 2010 | HP w17e Monitor
My w17e monitor says "input not supported"
Not quite sure what the question is that you have not already answered for yourself.
That monitor's maximum resolution is given as 1440 X 900 at 60Hz and installing a more powerful video card won't change that.
http://reviews.cnet.com/lcd-monitors/hp-w17e-lcd-monitor/4507-3174_7-32735619.html?tag=mncol;psum
JOAT
Sep 29, 2009 | HP w17e Monitor
W17e says "input not supported"
Hi - here's what I found about your wide screen monitor:
The HP Pavilion w17e LCD wide-screen monitor has the following features:
  • 1440 x 900 factory-set resolution
  • Supports VGA analog signal video input
  • Plug and play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Download & install the drivers for the monitor based on the version of Windows you are running from the HP site below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=pe&dlc=es&product=3377546&
Once the drivers are installed, your issues should be resolved - the driver will allow only the modes that can be displayed on the monitor - probably giving you options for resolutions you hadn't seen before.
Sep 29, 2009 | Acer AL1916W 19" LCD Monitor
Identify cable & where to connect to get audio on HP w17e monitor
male mini-stereo to male mini-stereo
Plug into LIME GREEN port on computer.
Dec 28, 2008 | HP w17e Monitor
HP w17e monitor
buy a new computer
Mar 13, 2008 | HP w17e Monitor
HP w17e Monitor Logo
129 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
