I bought LCD TV 32"
  • 23 Answers
Check to make sure that the power cord is plugged in. If it is, plug something else into that outlet to test and make sure that the outlet works (use a lamp or something that you know works). If the outlet doesn't work, check your breaker box for a popped breaker. If the outlet works, and you are sure the power cable is connected properly, then you need to return the TV to the store where you bought it. Most retailers have at least a 30 day return policy for defective merchandise.
Posted on Apr 03, 2011
Testimonial: "I suspected that it is something like that. The outlet works, the standby light is on. Just not the TV. Thank you for your helpful suggestion!"
I just bought 32 inch 2 hours ago, and am using it with an antenna. Almost every time I turn to channel 5, the remote freezes and I can't even use the buttons on the side of the tv. I have to...
This is my second set in as much days from Best buy. Exact same problem.
Sep 21, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
My 32LG350 wont turn on. I just pluged it for the first time i bought it like a month ago. it was working but suddenly it turned off by itself and wont turn on either by pushing the TV on/off boton neither...
Try unplugging the the TV from the power outlet for 30 seconds to a minute and plug back in again. Try to turn on again. Some TV's have to be in a "ready mode" to operate by remote - so besure it is in that mode - or use the power button on the TV.
Apr 01, 2011 | LG 32LD350 32 in. LCD TV
I have a SOYO-DYLT032B...32in LCD and I need a main module...not hopeful based on research...any clues?
what is the code for soyo tv 32" lcd to activate my digital remote to use it for all functions instead of using two remotes one to turn off and on and the other to navigate.
Nov 07, 2009 | Soyo DYLT032D 32 in. LCD Television
Tv remote and universal remote suddenly do not operate tv
All you need to do is unplug your television and plug it back in 2 minutes later. After you plug it in, try to use the remote to turn it back on and see what happens! Good luck to you
Mar 19, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
Problem with buttons on TV
replace infrared (IR) diode from remote control 100% working or sent me ur remote control i'll fixed for free..dont forget the fee for postage..my email add mandark_jeff@yahoo.com
Feb 09, 2008 | iLO 3200 32 in. LCD Television
Remote control
The IR detector has failed. it is inside the tv and it is not a do it yourself job.
Dec 12, 2007 | Sylvania LC370SL8 37 in. LCD Television
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
