Question about Microwave Ovens
I have a Panasonic NN A873 Microwave/Oven/Grill which has been working perfectly until yesterday. It has been built-in to my new kitchen using the correct kit from Panasonic, the day it was built in it worked as before but yesterday when I wanted to use it I couldn't get it to work. The clock was working but each time I entered a programme it started but after a couple of minutes it stopped and I got a message saying to refer to the instruction manual. I did that but there is nothing in there to help me. During the afternoon I heard beeping coming from either the microwave or the oven but I couldn't see which one was making the noise. I would be grateful for any help/advice you can give me.
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave re-started
The Start pad on the keypad may be starting to short. If so, a new keypad (membrane switch) would fix it.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's at
http://www.microwavedisplay.com/keypad_replacement.pdf
We have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The part # needed is A64795790AP "membrane switch" for $46.88 available here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Oven Panasonic NN-5560A
Chances are your Start key on your keypad has failed.
It is part # A64795790AP "MEMBRANE SWITCH", it runs $46.88 and you can find it here:
If you would like to have us do this for you, we do that for $39.95 plus part costs.
ginko
  • 19396 Answers
SOURCE: microwave not working but oven and grill do
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on May 21, 2009
My panasonic NN-8500 microwave/convection oven the microwave part is working fine but,the convection grill defrost is not
Possibly the defrost heater element has failed. You will need to strip the cabinet off and use a multimeter to test the element. May also be the overtemp safety thermostat may have failed.
Nov 19, 2016 | Panasonic Microwave Ovens
Can panasonic microwave oven nn-cf771s be built in to kitchen unit?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 05, 2016 | Panasonic NN-CF771SBPQ
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
I have a panasonic microwave with convection oven, grill and steamer. When I switch on the microwave, the house fuse (16 amp) cuts out. With the other functions of the oven, it works fine. Do I need a new...
you have a short circuit.
test the a) HV rectifier b) Capacitor HV c) HV transformer d) Magnetron e) test the swich for door for short.f) circuit board main is short.
see the diagrams and proceed.
10_2_2012_12_41_44_pm.jpg10_2_2012_12_42_15_pm.gif10_2_2012_12_42_35_pm.gif10_2_2012_12_43_09_pm.jpg
Oct 01, 2012 | Panasonic NN-C994S Convection/Microwave...
On microwave mode the oven makes light buzzing noise and does not heat food. Convection oven and grill functions work perfectly. michaelchrys@yahoo.com
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Aug 17, 2010 | Panasonic NN-A811A Convection/Microwave...
Microwave stopped working while cooking. Is there a fuse?
If unit is built-in reove screws holding unit to cabinet.
Slide out about 2 inches to access 3 screws holding grill.
Remove grill to get to two screws holding control panel.
Fuse is behind control panel,
Jan 16, 2009 | Panasonic NN-H264 Microwave Oven
Microwave not working but oven and grill do
Dec 17, 2008 | Panasonic NN-C980 Convection/Microwave...
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
