Question about Canon i475 InkJet Printer
I have a Canon Inkjet i475D printer that has been sitting for a year or more. I've tried to use it today - and the print heads are apparently clogged. I've tried the cleaning and deep cleaning utility several times. The only place this has gotten me with that the color sees to print better - but my black ink has now stopped printing altogether. Earlier, it was at least doing a partial print - but black has stopped printing altogether. I have replaced both ink cartridges and both are now full. What do I do now?
  • Canon Master
  • 3,715 Answers
If its been sat for a year it will need new cartridges. ink drys out over time when empty it drys to the head as there is nothing to keep it wet.
Posted on May 15, 2017
tenorsax
SOURCE: Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Posted on Aug 17, 2008
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
  • 68 Answers
SOURCE: Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
Posted on May 28, 2009
SOURCE: black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Try wiping the print head with a soft damp cloth - it works for me.
Posted on Oct 03, 2009
  • 1587 Answers
SOURCE: The black ink won't print on my canon iP5200.
Try removing the cartridge and cleaning the cartridge contacts in the printer with a cotton swab dampened with isopropyl alcohol. When the contacts are dry, lightly scrub them with a white pencil eraser (the red ones are too coarse and may cause more problems), then wipe clean with a dry cotton swab.
If that doesn't help, open up the printer and find the other end of the ribbon cable connected to the print head carrier. There is often some sort of locking clamp on that connector. Unlock it, pull out the ribbon cable and clean the contacts on that end, then reassemble. (The lock may be a sliding sleeve around the cable (it only comes out about a millimeter) or a flip-up plate. If there is nothing like that, the cable is a friction fit and pulls out with a small amount of force. Some very cheap printers use a permanently attached connection).
Explanation: It is possible that there is a second drive voltage to the print heads that isn't connecting, but its failure doesn't prevent normal communications to the cartridge using the logic level voltage.
Posted on Dec 09, 2009
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Remove print head canon mp480
THe print heads are an integral part of each cartridge. When you remove the cartridges you actually remove the print heads. You will need to open the top front panel to access the print carriage which moves left and right over the paper under it. Using cotton swabs you can apply rubbing alcohol to the places the cartridges rest upon and absorb all the dried out ink. Be sure you toss the old cartridges out before you reassemble. If you need to store any ink type printers REMOVE ALL CARTRIDGES and clean off the receivers on the print carriage!
Dec 31, 2012 | Canon Pixma MP480 All-In-One InkJet...
Canon pixma mp530 not printing colour. The cartridges are new, when I print an alignment, no colour prints, only the black and white. I've performed a clean, deep clean, print head alignment, nozzle...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon bjc 5500 inkjet.used as a plotter for cad drawings. no problems for a number of years. when the power button is pressed the LCD flashes on for half a second and then ONLY the ink icon is showing...
try this, it was usefull to me
Online blinking
Check and see if the print head is sitting in the middle
Typically means replacement of the print head, try reseating the print head
Feb 27, 2011 | Canon BJC 5500 InkJet Printer
I have tried deep cleaning several times on my Pixma iP5000 but can still not get the blue and magenta colours. Thr printer has been stand still for approx 4 years. Black and yellow works fine.
You need to replace the print head to fix the problem. You can't let ink printers sit for years. Especially when the print head is a part of the printer and not the cartridge.
Sep 28, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
I475d failing to print
uninstal the driver and reinstal it , recalibrate the printer.
Jan 16, 2009 | Canon i475 InkJet Printer
Canon i475D Printer
Try cleaning the rollers where the paper feeds in, a cotton bud with metho works on my printers
Apr 15, 2008 | Canon i475 InkJet Printer
Every 4th or 5th line does not print
try running your maintenance program.
go to your printer settings
right click on canon i850
left click on properties
run cleaning or deep cleaning,
then print head alignment and/or nozzle check
Dec 19, 2007 | Canon i850 InkJet Photo Printer
Canon i475 InkJet Printer Logo
old marine
old marine
