Question about GE JEB1090BV/WV Microwave Oven
I have a Ge JEB1090 bv built in microwave, the problem is the power failed last night for just a short amount of time and this morning the microwave will not heat anything. It seems to function as normal but the sound seems muted and of course the main problem is its not heating anything.
SOURCE: GE Over range microwave, JVM1660
It happened to me too. Thanks for the part #.
Posted on Feb 12, 2008
stonephoenix
  • 563 Answers
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Posted on Feb 04, 2009
najah
  • 180 Answers
SOURCE: GE Spacemaker XL1400 microwave doesn't heat anythting
Magnetron may be defective. Replace the magnetron by a new one.
Posted on May 01, 2009
localwonder
  • 6784 Answers
SOURCE: turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
Posted on Jun 01, 2009
sams_trix
  • 93 Answers
SOURCE: GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Posted on Aug 29, 2009
GE Spacemaker arcing?
It is possible, but you heard a similar bang earlier, from the description the magnetron is arcing on a occassion because it is failing, or there is bare metal exposed on the interior. I would recommend getting it checked out to make sure there is no safety hazard and have it resolved.
May 02, 2012 | GE SpaceMaker Microwave Ovens
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
Our GE built in microwave model # JKP62G suddenly started making a loud noise when we try to use it. It does this on any power level and on the defrost setting also. It does not seem to be heating...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 01, 2011 | GE Microwave Ovens
I have a GE Spacemaker Model JVM16400BB004 over the counter microwave, that was working fine last night turn it on this morning and it lights up and the turnatable goes around and sounds just like it use...
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I own Microwave /Convection Oven JVM1190. I used it last night but in the morning no power.
There is a small thermodisc temperature protector in the top of most MWO that cuts off power when over temp was reached or maybe fails all by itself.
I replaced two last year with resettable type but getting to them is a large job all by itself. RE: removing the top cover
Jan 31, 2010 | GE Microwave Ovens
Aug 29, 2009 | GE JVM1850 1000 Watts Microwave Oven
Spacemaker quit working.....
sounds like a short in unit and if it is then must be taken apart to observe operation and failure spot. depending on the age GE has warranties that cover magnatron up to five years< most likely cause of problem> suggest calling company before procieding any further.
Apr 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker Microwave is not getting enough power
the dimming of the light indicates a big amount of current being drawn by the magnetron. can you see sparks inside the oven?..it looks like the magnetron is shorting out with the ground. what makes it short to ground could be in the wave guide cover...look for some dark spots or accumulation of carbon from old food residue which becomes carbonized due to repeated heating. carbon is a conductive material that shorts the magnetron to ground.
i hope i was able to help
Jun 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
189 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
