Question about Miele Washing Machines
I have miele w3922 washing machine and it's displaying fault code F53 which I believe is the speed sensor, can anything be done other thgan call an engineer?
3 Suggested Answers
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
  • 70 Answers
SOURCE: How do I fix a F53 fault ona Miele W1712 Washing
F53 is a motor fault, Most likely the Tacho open circuit. Tacho comes part of the brush module assembly. You will need full model and index number before ordering part.
Posted on May 24, 2011
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
Dec 10, 2016 | Miele Washing Machines
How do i do is showing;tech. fault F53 and F63
F53 indicates that it is the issue of speed sensor. You can unplug the washer then plug it back in and set sanitize cycle. As soon as it begins,cancel the cycle. Then try any cycle again and see what happens. These washers have a severely sensitive balance system.If the load is at all off balance,it should at least attempt to get revving up. If it does f53 again, check to make sure it is firmly balanced/leveled onto the floor firmly.Try again and if it fails, please contact the Manufacturer
Jul 22, 2016 | Speed Washing Machines
How do I fix F53
This is a speed sensor fault. Could be caused either by the motor itself (built-in speed sensor) or by an electronic fault.
What is most likely depends on your model. See Miele goedkoop repareren cheap repair preiswerte Reparature
Mar 03, 2015 | Miele Washing Machines
I have fault of f53 what does this mean
Hi, Below is a post by a previous fault to you washer, I hope this helps you. taurustech
  • Rank: Guru miele.gif
  • Rating: 92%, 159 Votes
i,
All the credit goes to taurustech
Jul 15, 2011 | Washing Machines
What the meaning of f53 ptoblem?
Error code F53 on Miele is a speed sensor fault.
It has detected the drum speed to be wrong at some point and has indicated the problem to you.
Have you tried unplugging it. That will reset the computer.
If it's not coming up again after unplugging it, I'd not worry about it.
If it is coming up every time you use it, then you have either a faulty sensor, motor or pcb.
Miele are extremely secretive with information on their appliances and this makes it hard to diagnose accurately faults on them.
May 16, 2011 | Miele Novotronic W1930 Top Load Washer
How do I fix a F53 fault ona Miele W1712 Washing Machine
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
Cheers!
May 01, 2011 | Miele W1926A Front Load Washer
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
May 21, 2010 | Miele W865 Front Load Washer
Washing Machines Logo
113 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
