Question about Craftsman Garden
Craftsman lawn tractor model 917.270810. Have what appears to be moisture bubbles in oil. Have oil leak also maybe around engine gasket. What causes the moisture....the gasket leak? It is an air cooled engine.
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
SOURCE: 20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
Posted on May 06, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 376 Answers
SOURCE: gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
Posted on Jun 08, 2009
I have a b&s model 330000 engine which seems to leak a small amount of oil on the left side of the engine ans accumulates on the frame rail of the lawn tractor before dropping to the ground. i rec
My guess, without seeing the engine would be a seal or gasket is bad. Use Gunk brand degreaser to clean the engine. Start it up after that with the engine cover off and watch for leaks.
Jun 23, 2014 | Simplicity Regent 22 44 Riding Lawn Mower...
Craftsman lts1500 engine problem.
resecure the dipstick tube fill with oil and restart motor and observe tube at seat for any leaks and listen to motor making sure no internal damage was done if no issues your good to go
Apr 16, 2017 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman 17.5 hp tractor that will start but soon cuts off. I have replaced gas. battery fuel filter and spark plug. Also burning a lot of oil to me.Have replaced fuel lines also. Seems to not...
Could be a head gasket. I'd recommend a compression test or better yet a leak down test that will show where the leak is. Hope this helps. Please vote yes, thank you
Nov 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn tractor is smoking
Make sure that it is at least 18 years old. Then look at the valve cover gaskets. The gaskets frequently leak and the oil drips onto the exhaust pipe. They will be near the spark plugs, have two small bolts holding them on.
Oct 30, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Craftsman Tractor 42" cut. It's burning oil and smokes when I start the blades.
perform a cylinder leak down test, any readings over 30 percent loss means the engine may have internal problems, Many things it could be. Blown head gasket that is blown between the cylinder and oil gallery. Overfilled with oil or gas in the oil from a faulty carburetor. Leaking valve stem seals. Worn piston rings. Hope this steers you in the right direction. Good luck
Nov 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
Nov 07, 2009 | Craftsman Garden
Garden Logo
119 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
