Question about Nakamichi CD-35z CD Changer
Our Nakamichi CD player has frozen up on us. Our Nakamichi Cassette Deck door won't close and prior to that it tangled a cassette tape and quit working. Both were purchased in 1991 along with a tuner/receiver.
  • revandmrse Aug 05, 2008
    To be more accurate, the compact disc changer is a Nakamichi CDC-4/CDC-3 and the Nakamichi Discrete Head Cassette Deck is CR-4/CR-3. Thanks
    Scholar:
  • 144 Answers
The CD player muigt be able to rescue by a reset top factory settings, mostly available in your manual, the cassette deck i think needs to be repaired.
Posted on Aug 08, 2008
How to fix sony camcorder with tape deck that won't close. camcorder squeals and ejects tape.
bit late...but. STOP ASAP! by removing the battery, after removing battery, wait 20 seconds, re-fit battery & CLOSE the cassette door.
then wait 10 seconds, slap the closed door twice quite firmly. then open, if it opens, discard that cassette tape, clean the players head using cleaning tape.
use new cassette tape.
Jun 30, 2015 | Sony Video Cameras
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Nakamichi DR 10 does not eject. I loaded a cassette, pressed 'Play' the cassette played 10 seconds and stopped. The display showed 'ERR'. I removed the cover, nothing immediately obvious. The cassette...
The DR1o might have a Sankyo transport and they have sense fingers that become tarnished. This needs to be serviced to make the deck work. It is possible that the deck is still in play mode which blocks the eject from taking place. Unplug the unit and open it up and rotate the worm gear with a finger and the door will eventually open up but do not force things as understand the size of motor in the unit that normally turns the worm gear.
Sep 19, 2013 | Nakamichi Audio Players & Recorders
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
How do you get a tape out that is stuck
Probalby the only way to get stucked tape out of a player is in pieces. Then repair the cassette and clean your player. If it keep stcking tapes, dispose it.
By the way, cassette tapes an players are rather obsoleteby now. Any digital source is better quality the a cassette.
Aug 28, 2010 | JVC TD-W118 Single Cassette Deck
Inserted tape into the cassette and the door will not open so I can remove it and it will not play as inserted.
use a paper clip to release it. there is a tiny hole located close to the deck, insert the pin and it shuold open. the tape might be tangled...
Jul 02, 2009 | Audio Players & Recorders
Connecting Nakamichi 600 cassette deck to speakers
You must have an amplifier or receiver to connect between deck and speakers. The deck has no power amp
Aug 03, 2008 | Audio Players & Recorders
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
Nakamichi CD-35z CD Changer Logo
267 people viewed this question
Top Nakamichi Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Jaime Hernandez
Mohamed Ismail
Mohamed Ismail
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
