Question about Plumbing
I have a leaking radiator. The radiator leaks when the thermostat is put into the 'closed' or 'off' position. The leak occurs from the knut below the thermostat. I have tried to tighten this knut but it wont move. I would have presumed that a radiator would leak when in the 'on' position but mine seems to do the opposite!
    Champion:
  • 231 Answers
Hi this is a common problem with radiator valves, the gland under the nut needs replaced or repacked as it will be worn
Posted on Apr 08, 2011
  • mikepemberto Apr 08, 2011
    Thanks for your response. Do you know if this is an easy job for a novice or whether i should ask a professional?
Anti freeze leak I hear hissing sound under neath fuel injection system
could be leaking at the top radiator hose going to thermostat, that is a hard spot to see leak remove the air filter and air filter housing look below throttle body you see thermostat housing, check for leaks around thermostat housing gasket and check for leak at the top radiator hose going to radiator and thermostat.if all is good check all radiator hoses for leaks check small coolant lines going to throttle body for leaks and check make sure bleeder screw on thermostat housing not loose it will leak also check around radiator and water pump heater bypass metal lines for leaks.
Sep 10, 2012 | 1999 Chevrolet Lumina
STEAM COMING OFF ENGINE
check top radiator hose goes to thermostat housing sound like its leaking if your engine leaking from left driver side on top of engine it has to be top radiator thermostat hose leaking.wait until engine cool down replace top radiator hose see if coolant leaking still occur if so you could have radiator leak.
Dec 09, 2011 | 2002 Buick LeSabre
I keep geting a low coolant indicator when it first starts in the morningalso it keeps overflowing and boiling our of the overflow tank. This happens even when ythe coolant level is below full.
Either the thermostat is stuck in the closed position...or the engine cooling system cannot pressurize...both will cause an overheat condition.
A blown head gasket can cause overheat condition as well as fluid loss (boil over)
I'd maybe remove the thermostat and either just replace it or not have a thermostat installed just to see if it still boils over. If it boils over with no thermostat installed then you're getting into possible leak in cooling system...i.e. water pump weep hole, hose or radiator leak...or a blown head gasket.
Hope this helps...
Aug 28, 2011 | 1995 Jeep Grand Cherokee
My 1999 Alero must have a leak somewhere because the thermostat gauge rises every few days. I put coolant in it at least 1 a week. I had a new water pump and thermostat put on it, but it is still...
CHECK AROUND WATER PUMP AREA.AND THERMOSTAT HOUSING FOR LEAKS.THE MECHANIC WHO PUT THE WATER PUMP ON MAY FORGOT TO PUT SEALANT ON BOTH SIDES OF THE WATER PUMP GASKET CAUSING LEAKS.LOOK AROUND THERMOSTAT HOUSING FOR LEAKING.IF THERMOSTAT SEAL WAS DAMAGE DURING INSTALLATION IT WILL CAUSE LEAKING.IF ALL LOOKS GOOD CHECK FOR COOLANT LEAKS AROUND RADIATOR .CHECK RADIATOR TOP AND BOTTOM HOSES FOR LEAKS AND CHECK HEATER PIPES AND HEATER CORES HOSES FOR LEAKS.IF ALL HOSES GOOD.CHECK FOR LEAKING CORE PLUGS.
Sep 26, 2010 | 1999 Oldsmobile Alero
Engine hot temperature high loosing colant
Check for radiator leaks, hose leaks, try to locate the area were the leak is occuring. You may need a new thermostat. If you can locate were the leak is, chances are you'll find the area in need of repair.If coolant is running from small line " hose from radiator or coolant bottle", could be a faulty thermostat.
Feb 27, 2009 | 1996 Lincoln Continental
OVERHEATING
This could be a multitude of things:
Stuck closed thermostat.
Cooling fan not coming on.
Clogged radiator.
Low on coolant.
Water pump failing/leaking.
Head gasket blown, leaking exhaust into antifreeze.
Clogged catalytic converter.
Thermostat: If the Van heats up, then feel the upper radiator hose. If it's cold, then your thermostat is closed. Replace thermostat.
Coolant: If low, simply fill with distilled water and coolant. Low levels will let engine over heat.
Radiator: If there are cold-to-the-touch spots on the radiator after it should be warmed up, then a clogged is probably occuring. Have radiator flushed.
Head Gasket: If you smell exhaust fumes in your coolant reservois tank, then you got a blown head gasket.
Cat Converter: Only can be tested if off the car. Or you could try a non-contact thermometer. These are also good to testing cold spot on radiator or if thermostats are open.
Cooling fan: If mechanical it'll be spinning. If electrical, it should come on automatically with the A/C, or when it gets hot.
Water pump: Will be leaking from the front if it needs replaced. On a van, it's a tough job.
Feb 10, 2009 | 1995 Ford Econoline
Running Hot
you need to have a pressure check don on the radiator. this will pinpoint the leak if you dont see any leaks externally it could be a head gasket or a manifold gasket but the simplest thing to check is the thermostat. it may stuck in the close position and not letting you antifreeze circulate
Dec 08, 2008 | 1992 Chevrolet Suburban
2.3l ranger keeps overheating, been through two radiators already.
Hello Ranger Joe, eight months and two radiators is very uncommon. Question, Have you visually confirmed the leak in the radiators or is the leak near the hose connections? Replacing the radiator, cap, water pump, & the thermostat leaves only two others, the hoses and the engine block/heads. Far fitched will be something or somebody poking holes in the radiator.
Nov 07, 2008 | 2003 Ford Ranger Regular Cab
Leaking anti-freeze or water
Change out your thermostat gasket and upper radiator hose. This should fix the problem.
Oct 01, 2008 | 1993 Nissan Maxima
Leaking Antifreeze
Are you getting water in the oil?
Are you burning white smoke?
Depending on the moter size, it could be an intake gasket leaking as well.
2.0 has thermostat mounted to head and hose to Radiator, 2.4 has thermostat below radiator cap.
Best thing to do is have Radiator pressure test done and see where the leak is for sure. There are dyes that you can add to the radiator and you can see leaks with UV light.
Aug 04, 2008 | 1997 Dodge Intrepid
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
