Question about Nokia C5 Cell Phone
I am using a Nokia C5-00 phone that I got yesterday. Seems like it has the latest software version. But for some reason, it doesnt display the contact name during an incoming call or while listing missed calls. What can be done to fix this?
  • 943 Answers
This is a very common issue with nokia phones. It occurs mainly when you have stored a particular number with more than one name.
For example if you have a number stored to your sim using one name and you have it stored to your phone memory with another name. In most cases, when you install a new SIM card to a nokia phone, it might copy the contacts from the SIM memory to the phone memory automatically and add some extra information or edit the name automatically. This can cause a conflict between which name the phone should display when any action associated with the number is to be performed. In this case, it displays just the number.
To solve this problem without having to delete any contact, all you need to do is to go to your contact settings and then select which memory should be the default display memory.
Hope this helps you? Please comment for more information and thank you for using FixYa.
Posted on Apr 03, 2011
  • 133 Answers
I've encountered this issue before, what I did is I save the contact first in my phone memory and activated it as default memory for contacts and deleted all the existing logs of the said contact number. Try to do it.
Please don't forget to rate! Thanks!
I REQUIRE LATEST SOFTWARE UPGRADE NOKIA 5800
The latest software version of Nokia 5800 is version 60.0.003.You can do it via OTA (over the air) thru GPRS (mobile service providder's internet gateway) or via wi-fi connection or even via PC suite.
OTA via GPRS:
1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your mobile service provider's connection.5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go...
VIA Wifi:
1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your wi-fi home network connection5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go...
VIA PC SUITE:
Go to this address and follow instructions (make sure that you have available USB cable for your phone for you will need to connect to your pc to do this):
www.ovi.com/softwareupdate
thanks for choosing fixya.com
Dec 17, 2011 | Nokia 5800 XpressMusic Smartphone
Tip
Nokia phones secret codes
Here are the secret codes of nokia mobile phones and will work on most of the latest nokia mobile sets. You can display the hidden information of mobile sets and troubleshoot the routine problems using these codes.
Follow the list of latest nokia codes list:
Code : Action
*#7780# : To restore the factory settings of mobile set
*#3283# :To verify the set Manufacturing date
*#746025625#: To stop the sim clock
*#67705646# :Use to delete the operator logo
*#73# :Use to reset game scores and phone timers
*#0000# : Use to display the mobile software version
*#06# : To display the IMEI Number of the mobile
*#92702689# :
To display the mobile warranty related settings
*#7760# : To display the Production serial number
*#bta0# : Use to display Bluetooth MAC address
*#9999# : Use to display the mobile software version
*#147# : If you are using Vodafone then this code will help you show the last call detail
*#2640# : To display the mobile security code
*#7328748263373738# : Apply to resets the set default security code
*#43# : To verify the call waiting status
*#2820# : To verify the Bluetooth information
*#7370# : To format the mobile phone memory
*#delset# : To delete the GPRS AND EMAIL settings
#pw+1234567890+1# : To display the lock status of mobile set
#pw+1234567890+4# : To display the lock status of your SIM
on Jul 07, 2010 | Cell Phones
I want to update nokia e5
You need active internet connection for this:
1. press #0000#, then it will display you the current software version that your phone is using.2. press option, then select check for updates.3. it will then go to connecting to internet, select yes.4. if there is available update, you will be provided instructions that the phone is updating software.5. you will be ask to replace the old version with the new version, just select YES.6. your phone will restart, that's part of the software update.7. after restarting, your phone will now be using the latest version available for your phone.8. you can again check the current version of the phone's software by entering *#0000#, then you are good to go.
You can also try to this:go to settings --> software update --> download available updates --> phone will restart --> you will be using the new version of the phone's software after this.
Thank you for choosing www.fixya.com
Dec 08, 2011 | Nokia E5 Cell Phone
Nokia N 70 switch on it will automatically off after 5 or 6 second what i will do? My battery is OK. when i try to format it automatically off.
Could be a virus.. format your phone using this method... turn off your phone.. press answer call + 3 + * and turn on the phone while keep holding other 3 keys.. it will format your phone..
If the above doesnt work, reinstall phone software using nokia software updater.. download nokia software updater.. connect your phone with pc using USB cable.. it will search for any available update.. if it says you got latest version... check the option reinstall current version..
Apr 13, 2011 | Nokia N70 Cellular Phone
I CANT SEEM PICS IN MY MEDIA JUST BLUE SCRENN???
If your phone is freezing on display of pictures, I recommend updating your firmware & system software to the latest version. The latest BlackBerry Bold 9700 system software is available through here.
Feb 11, 2010 | RIM BlackBerry Bold 9700 Smartphone
I want to latest update for my nokia 7610 phone software
Dear u can find the latest firmware update available for ur phone at the nokia.com/softwareupdate.You can update if any update is available via NOKIA SOFTWARE UPDATER.
Dec 07, 2009 | Nokia 7610
New nokia 6303 and it freezes
i have a nokia 6303c when i power on tis ok but after a few seconds the screen fades and becomes black then hangs and remains with lights on
Nov 10, 2009 | Nokia 6303 Cell Phone
Software problem of nokia6280
i have nokia 6280 having display problem
Feb 01, 2009 | Nokia 6280 Cellular Phone
Operamini doesnt work on my Nokia 3230
First of all check the version of operamini you r using. I guess latest is OperaMini 4. Check if you have proper network coverage on your mobile. Could be this reason.
Sep 13, 2008 | Nokia 3230 Cellular Phone
Nokia C5 Cell Phone Logo
512 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
