Question about Labtec LCS 1040 Computer Speakers
I have not sound and it tell me its not connected
  • Labtec Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 03, 2011
I want to purchase the 28 inch TV - however when I reviewed the literature I couldn't figure out if our sound bar (Samsung model # HW-C451) would hook up to it - we only have a fiber optic connection...
Well before I can tell you if there is an adapter available, you need to tell me what kind sound outputs are available on your tv. Please provide this info so that I can tell you whether there is an adapter available.
Mar 27, 2011 | Hannspree 28" Widescreen Flat-Panel LCD HD...
TV- some channels don't have any sound, other channels do
RE TUNE UR TV AGAIN AND LET IT FIND ALL THE CHANNELS.......IF PROBLEM PRESISTS CALL PANASONIC SERVICE AND TELL THEM OR PROBLEM U HAVE IM SURE THEY WILL TELL U WHAT TO DO .........OR MAY OFFER U FREE SERVICE......WHAT WILL BE UNDER THE WARREN TIE U HAVE FOR 12 MONTS
Nov 20, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Switch our tv to souround sound
Surround sound will come from the speakers from your surround system. So if you have it connected through HDMI 1 select that option from the source button on the remote control. If you have it connected through Scart 1 then select AV1 from the source button. It also best to turn the volume from the TV to minimum so that the sound only comes from the surround speakers.
Mar 23, 2009 | LG 47LG50 47 in. LCD HDTV
Unable to connect ipod touch to home network
Sounds like an I.P. problem. If set to "Dynamic", try "Static" IP. Had a similar problem with my Linksys wireless camera. It worked...than it didn't. Sounds eerily similar.
Mike
Feb 16, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
No Sound
go to standby hold m-log button tell menu comes on display press up on volume control tell amplifier comes on display pess left on volume control tell display says amp on. the built in amp on the stereo turns of and on to provide better sound quality to the pre-amp out puts
Oct 03, 2008 | Kenwood KDC-X590 CD Player
Connecting to computer
First, check all cords of course. Make sure power is in an outlet that works, green cord with the green port on the computer. (Check that you are plugging the right colors together, if so look below)
If you could tell me what type of sound card your computer has, I can guide you through.
(Sound cards)
There are PCI sound cards or/and Integrated sound cards for most situations. A PCI sound card would mean that you have a physical card which would look like this, with more or equal speaker jacks :
Or if you have an Integrated sound card then the back of your computer might look like this (Sound portion includes the 3 female jacks furthest to the right):
f53cb0c.jpg Or you might have both, if you have both plug into the PCI sound card since that more than likely is the way the computer is setup.
Jan 14, 2008 | Altec Lansing Multimedia Computer Speakers
Amp arc
What you need to do is first ground your amplifier securely then make sure all connections are fastened. don't remove the speaker connection and listen for sound. If there is no sound power down the unit, and send it to a repair shop because it sound like you may have damaged some components in the unit. But in order to come to this point you have to make sure you ground the unit properly and then make sure all of your connections are secure. Contact me once this is done and you are ready to do some tests.
Aug 28, 2007 | Rockford Fosgate Punch P5002 Car Audio...
Labtec LCS 1040 Computer Speakers Logo
60 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
