Question about Kenwood Car Audio & Video
I'm trying to install a Kenwood krc 1006 into a 75 Ford f350 I need to know what I connection my speakers to on the radio. Which colors are which on the wiring harness
Buffalo12980
  • 625 Answers
SOURCE: wiring-audio system-1989 ford crown victoria
go to an autozone or advance auto parts store and find a haynes auto manual for your car. electrical diagrams are in back of the manual.
Posted on Dec 07, 2007
idkia_33
  • 70 Answers
SOURCE: FORD RADIO WIRING COURIER 2003
go to this site
www.autotoys.com/New_Tech/Wire_codes/wire_codes.htm
Posted on Jan 22, 2008
  • 17 Answers
SOURCE: wiring colors
You will need a voltmeter. Normally red is power, black i ground, yellow is memory power. the best way to know for sure is to use a voltmeter to test what each wire is recieving in power and when. If the key is off then the wire that has 12volts dc is for memory and the main power wire should be at 0volts dc. When the key is on that wire should have power now. the ground will be black on that car. Good luck.
Posted on Feb 20, 2008
tech48
  • 624 Answers
SOURCE: I recently bought a 1994
Yo most likely have a bad speaker or the amplifier IC inside the radio is bad. More often than not, it is the amp IC.
first double check that you have all speakers connected right and that you don't have a speaker wire that may have an exposed area that could be shorting against the car chassis.
You can check the speakers by disconnecting them one at a time and see if the sound returns to the remaining speakers that are still connected. After checking one speaker, re-connect it and try another.
If the sound returns after dis-connecting one speaker, that speaker is your problem.
If none of this helps, you will need to get it serviced. If you are skilled with soldering and can dis-assemble and then properly re-assemble a radio, this is a very easy fix and I can look up the part number for you of the amp IC. it is also right on the IC itself. If the amp IC is blown up badly, you will see burn markes on it and sometimes a piece of it can be blown right off of it. In that case you will not be able to read the part number.
Normal repair cost for this type of a problem run between $80 and $120 at most shops, depending on the shops rates.
This is a very high end cassette player and in it's day cost about $400 back in 1997 when it came out. But todays car stereos are nearly as good built, and cost much less.
You can get a good car stereo with CD for about $150, cheap ones for $100.
Let me know if you need any further help, and if you found that this information was helpful a good rating would really be appreciated.
Thanks and have a great day,
Dave
Posted on Jun 21, 2008
emissionwiz
  • 79077 Answers
SOURCE: i need the color wiring for a ford expedition radio
1997 Ford Expedition Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Purple
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6′ x 8′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: 6′ x 8′
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Light Blue/Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Purple/White
Right Rear Speaker Negative Wire (-): Light Blue
Posted on Mar 26, 2009
Loud speaker connection kenwood krc 152l
Hi Carlo,
May I suggest you join yahoo group specific to your radio Make/Model,
there you will get all the info plus free manual & schematic downloads as well as other goodies.
I hope this is useful.
Cheers,
Peter
Mar 01, 2013 | Radio Communications
Im tring to match up this radio wireing to a chrysler lhs i need to know what colors go to what the kenwood krc 235 wire to the chrylser car wireing (red to pink blue to orange like that)
I recommend you purchase a wiring harness specific for that vehicle instead of trying to hardwire it. You run the risk of frying your entire electrical system if you do. Wiring harnesses are about $7-$20. Plus, it takes the guesswork out of wiring. Visit www.crutchfield.com if you are looking for one.
Aug 14, 2011 | Car Audio & Video
How do i connect a kenwood krc 394 radio cassette,+ve battery, eth, and speaker connections.
Head unit color code:
12V-Yellow
12V switched-Red
Ground-Black
Illumination or Dimmer-Orange/Orange w/white stripe
Blue-Power Antenna
Blue wwhite stripe-Amp turn on
Whites-FL speaker
Greys-FR speaker
Greens-RL speaker
Purples-RR speaker
(Black stripes negative)
If you have a female harness to connect to the veicle side you will pretty much color match. The only exception is that you may only have an amp turn on wire but only a power antenna on the vehicle. In this case you would connect blue w/white stripe wire from radio harness to the blue antenna wire on the vehicle side.
If you are doing a hardwire (factory plug has been cut off) you can obtain a wiring code for your vehicle at www.the12volt.com for most vehicles.
Jun 06, 2010 | Kenwood KRC-394 Cassette Player
Wiring diagram for Kenwood KRC-2007?
red wire is key source black wire is ground yellow wire is menory 12 v source is that is on all time rest are speaker wires make sure u put the full color wires as ur pos side then the wires with a blk line thur is neg side
May 15, 2010 | Kenwood KRC-2007 Cassette Player
I have a kenwood krc-2001 and im wondering what and i need help
I'LL MAKE THIS VERY EASY FOR YOU, IT WILL ONLY COST YOU ABOUT $25 MAYBE LESS. JUST GET A WIRE HARNESS FOR YOUR CAR, PEPBOYS OR ANY AUTO STORE, JUST TELL THEM THE YEAR AND THE MAKE OF YOUR CAR AND YOU WILL BE SET, THE WIRING IS COLOR CODED, MAKE SURE THE HARNESS CONNECTS TO YOUR FACTORY HARNESS.
Mar 15, 2010 | Kenwood Car Audio & Video
I HAVE A KENWOOD KRC-2007 CAR STEREO AND DON'T KNOW WHICH COLORED WIRE GOES TO THE LEFT AND RIGHT FRONT SPEAKERS, I THOUGHT IT WAS WHITE/WHITE BLACK AND GREY/GREY BLACK.
Hello! Front Right; + = Grey... - = Grey/White
Front Left= + = White... - = White/Black
You are correct...Perhaps you need the vehicle's colors?
If so send a comment with year, make and model...
Guru.....saailer
Feb 17, 2010 | Vehicle Parts & Accessories
I have an old Kenwood KRC 2001 cassette radio which I would like to fit to a car just bought by my daughter but it has no electric/speaker connector. Can anyone please tell me what output/input each of the...
red is battery. some have two red wires, but they are both battery(12 volts). it is a switchable 12 volts which means it comes on when you start car. yellow is a constant 12 volts. it is for memory. blue is for power antenna(ive never used it. i keep blue wire disconnected) then you have the set of colored wires like green and gray stripe. those are speaker wires. match it with its other color coded wire. example.....brown with yellow stripe wire goes with the brown wire to connect speaker. enjoy
Nov 21, 2009 | iLO XM-MP3-CD Car Stereo
Color code radio wires 1990 ford truck F350 4 w/d
Battery GREEN/YELLOW (+) RADIO HARNESS
Accesory YELLOW/BLACK (+) RADIO HARNESS
Ground RED OR BLACK (-) RADIO HARNESS
Illumination BLUE/RED (+) RADIO HARNESS
LF Speaker (+) ORANGE/GREEN
LF Speaker (-) BLACK/WHITE
RF Speaker (+) WHITE/GREEN
RF Speaker (-) BLACK/WHITE
LR Speaker (+) PINK/GREEN
LR Speaker (-) PINK/BLUE
RR Speaker (+) PINK/BLUE
RR Speaker (-) GREEN/ORANGE
radio Security YES
Feb 20, 2009 | JVC Car Audio & Video
Kenwood krc 479r
If there was no spark and wires hooked up wrong in the first place, your player should work if you find the PWR lead and the Remote lead and ground. Then speaker wires +) and (-
Sep 25, 2007 | Kenwood KRC-479R Cassette Player
Car Audio & Video Logo
96 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
