I have a panasonic Hd Tv 1080i (52") the sound is not working. Tv was on and just quite. No static or pop before it stopped.
    Scholar:
  • 67 Answers
Can you send me the model number for this tv and I will do research for this problem. But the audio is generated by the main board, which might be your problem. You can probably also go into menu-sound and see if the speakers are turned on.
Posted on Apr 03, 2011
Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Jul 04, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
I have a panasonic 52"
The tv projection lamp timer must be reset,read ur ower manual how to do that or call panasonic customers service for the help with the prosedure,sorry i don't remember how to do it anymore.The problems with the HDMI 2 setting all the time.Tries tv unplug,replug the tv back about an hour later for the tv to do a resetting itself back to the factory setting.Than go into the tv Menu changes to all the manually setting and turn off all of the auto functions of the HDMI hubs setting should solved this problems.
May 09, 2011 | Panasonic PT-52DL10 52" Rear Projection...
The tv is only 4 years old and just stopped working while we were watching it. it is a "52 model number pt-52lcx65-ka.
If lamp in tv has not been replaced in last 3-4 years then check lamp and replace it.
Did tv showed lamp replacement requires warning/ message on screen before going to shut down?
Did you hear any pop sound inside tv when it get shut down? that pop sound could be lamp that got broken.
Let me know if you have additional question.
Thanks.
Feb 27, 2011 | Panasonic PT-52LCX65 44" HDTV
Trying to hook up PS3 to Panasonic viera LCD hdtv with HDMI cable and tv is not reading it and has no picture or sound. What may be the problem? Thanks!
hi,
ur ps3's HDMI out is a full hd video (1080p). if u r tv does not support full hd this problem can occur. do one thing. connect the ps3 to any full hd tv and go to its video setup, then down scale its video resolution to 1080i. after that connect the ps3 to ur tv. u will surely get video.
ok
Jan 11, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
TV only formats at 480i
Check in your instruction manual to see if the set can actually work in 1080i. Most of the sets going back about 4 to 6 years ago were not capable of working in 1080i.
The signal coming to your Sat box may be in 1080i, but your Sat box has to be able to output 1080i. This can be quickly verified by calling the support for your service and giving them the model number of their Sat box.
Jerry G.
Dec 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wii w/ 1080I tv
yes, you won't get the full 1080i HD experience, but it will work.
Aug 14, 2009 | Panasonic Televison & Video
RCA D52130 52 in. Won't Display High Def
Hi!
I doubt you'll look at this 2 years later, or even have the T.V.
I have the same TV and was able to view ps3 and xbox 360 games in 1080i, but it's a little tricky. First, let me say that the ps3 is probably not the best system to try using 1080i in unless you have a 360 to help trick the tv into working.
Xbox 360
You need to first set the video to 1080i. This will make the screen display in a bunch of horizontal lines most of the time, but if you keep toggling it on and off, it eventually works. To avoid having to sit and swap between the two modes, it's easier to first set it to 1080i and confirm the setting, then go back into the settings, select 720 (first option above 1080i) and cancel as soon as the video mode changes. 95% of the time this will make it display correctly in 1080i mode. If you turn the tv off and back on, it will sometimes reset to the horizontal lines. If you restart the xbox, it will reset to horizontal lines most of the time. With the ps3, you can set it to 1080i and keep toggling it until it works, but when the game launches it can screw up again, so it's best to have the xbox on and ready with a component switch so you can fix it with the xbox then switch back to the ps3. I think the cable that comes with the tv for HD input (the component plugs don't work, they only support 480, but the vga looking input supports 1080i) - the cable is just poor quality and can barely handle the signal. I've been trying to find a better quality cable with no luck.
Hope this helps other people with this ancient beta HD input canadian tvness.
Dec 30, 2008 | RCA D52130 52" Rear Projection Television
Cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Panasonic Model # PT52DL52 52 " HDTV DLP (2003). Working fine and all of a sudden heard a pop and TV quit. It's not the bulb since fairly new and the bulp idiot light is not on. I think it may be...
Remove the lamp and look into the left side of that compartment to see if you can find glass/color wheel bits and pieces. I just recently had this happen and when I turn on the tv the red power on indicator blinks twice. Check to see if you have power to the tv
Aug 25, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
