Question about Vacuums
Where can you get replacement blades for a ConAir HC224?
I have a spin brush Conair infiniti pro and the brush stopped spinning. How do I fix it?
Replace the brush bar you'll have new brush bar better clean than old brush with new bearing which aren't available or worth the bother fitting, ps keep the filters clean makes a real difference to sucking power.
Oct 22, 2017 | Conair Vacuums
H o w to clean a ball tip bristles on a Conair hair brush?
with a comb . or throw it in the washing machine once in a while .
Sep 15, 2015 | Conair Vacuums
Steam cleaner sc20
It works like a squirt gun, submerge complete unit into water to add water. After it fills pull out and ready to use.
Jul 28, 2014 | Conair SC20 Handheld Steam Cleaner
I need a free instruction manual for FSP5 Conair Steamer Iron.
Hi cmarceau,
Welcome to fixya!
Here is the web address for your instructions: www.conair.com/cnt_ib.php?action=download&id=210
Copy and paste this address into your browser and the Adobe Acrobate will be ready to download for you.
Handie Andie
Jul 15, 2011 | Vacuums
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
I need maual for Revlon 1875 IONIC hair dryer Model # RV479 i want to download the PDF manual if possible
Well you may please follow the link below to get your manual -
http://www.conair.com/instruction_booklets/1875Watt_Ionic_Styler_146XR.pdf
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Vacuums
I have a Pro Steam Scunci Model PS-3888, Portable household steam
I own the PS 3888 and am just about to sell the entire unit at a yard sale. I would be glad to help you out but I think the mailing cost of the machine would be prohibitive.
Mar 07, 2009 | Scunci 52067 Handheld Steam Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
