Question about Dryers
How do i connecet wire plugon to dryer
Can not figure out ge dryer plug together really dn't understand how to do so
  • 101 Answers
Which country do you live in?
, what colours are available to you on the cable?
Posted on Aug 05, 2008
SOURCE:
Im need help figuring out how to connect wires to my GE dryer
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jun 16, 2011 | Whirlpool GEQ8858H Dryer
Hello all I have a GE DCLR333ETOWW Electric dryer. When we got it the start button was missing so I had the Blue and Brown Wires sticking out and we would just touch them together for a second and the...
first things first. Electric dryers are 220v on a double breaker in your breaker box. (120v for the motor,120v for the heater element). When your dryer sparked, it probably tripped the breaker. Note: you REALLY need to buy a switch an get those exposed wires back inside of the dryer where they belong...just sayin'
Apr 30, 2017 | GE Dryers
Have ge dryer changing from 3 prong power cord to four prong need diagram
The main difference between a 3-wire and 4-wire configuration is how the Neutral and Ground wires are terminated at the temrinal block. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
In a 3-wire configuration Neutral (WHITE) and Ground (GREEN or BARE COPPER) are terminated TOGETHER at the terminal block via a ground strap.
In a 4-wire configuration these two wires are independent of each other are NOT terminated together.
If you have questions, please let me know. I hope this helps you.
Nov 28, 2009 | GE DBXR463EBWW Electric Dryer
Gas Dryer tripping circuit breaker
YOU HAVE A CROSSED WIRE CHECK METAL CLIP IS NOT IN CONTACT WITH ANY EXSPOSED WIRES AND MAKE SURE IGNITER IS PROPER POISTION .
Oct 22, 2009 | Dryers
The system is not turning on the rear speakers for KLH HA9000
1. See if the rear speakers were pressed disable thru
your controls (either remote or in board). Just
press enable, to let it function.
2. If thedefect is still there, check the wires going to
the rear speakers if this is disconnected,
especially for plug on type. Open the plugon
connector and see the soldered wire at the
terminal. This could be disconnected. Have re-
soldered, and replace the plugon connector .
3. Then, power it up, and see if it works.
Sep 27, 2009 | KLH HA9000 Theater System
Changing dryer plugs
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 09, 2009 | GE DCVH515GF Gas Dryer
Control panel dead
1. Unplug dryer.
2. Remove 2 screws from rear top of dryer.
3. Lift panel assembly up, taking care to not pull wires.
4. Check plugs on circuit board for panel display. Press each one firmly, but carefully.
5. Put back together, plug in, turn on.
Jun 14, 2009 | GE Profile Harmony DPGT750EC Electric...
I want too change the wiring from wiee to four
you need to replace plugon the dryer. no way to plug a 3 prong into a 4 prong outlet
Mar 01, 2009 | Whirlpool LER5636P Electric Dryer
DRYER TUMBLES BUT WILL NOT HEAT
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
Jan 18, 2009 | GE DBXR463GD Gas Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
