Hi there i`ve got an lg50ps3000 plasma tv and when i switch it on by the power button i get a white screen at first for about 3 or 4 seconds followed by a fuzzy picture for about 2 seconds then it turnes itself off have you got any idea what the problem is thanks ....Dave...
  • davenh Apr 03, 2011
    thanks for getting back to me, the set is 2 n a half years old, i left the tv unplugged for about an hour then tried it again, it turned on and stayed on but the picture was fuzzy, i turned it off again and back on and had the same problem
    Scholar:
  • 67 Answers
How old is the set? It sounds like it may be a panel, Tcon or main board issue. The light you see is the backlight so we know the fluorescent tubes in the panel are getting the AC voltage. It is just not getting the video signal generated by the main board. The proper procedure is to try the main board first, if this doesn't work, then it is the panel or Tcon board. I will look up in my manual and see if the Tcon board can be ordered seperately from the panel. It might not, so in this case, the panel will need to be ordered. Only have an experienced technician install the panel if this is the route you want to proceed.
Posted on Apr 03, 2011
Testimonial: "thanks for getting back to me that would be great."
  • Jeffrey Strauss Apr 03, 2011
    Please send me your email address. I have a manual for your tv. Check out the troubleshootin section page 15. It seems you have a noise issue on the main board. If the video is not processed correctly, it will send the main board a signal and shut down the tv.
    hi thanks for helping i dont know if you got my last message about leaving the tv for about an hour and trying it again and it staying on with a fuzzy pic then turning it off and on again having the same problem (switching off and on without me touching it) i have just left it again and it is working perfect again ughhhhhh frustrating . my email is davenh@davenh.karoo.co.uk thanks again. ....dave....
Plasma inner screen cracked, and buzzing. Is it worth fixing the caps?
It sounds like this is an LCD tv - not a plasma.
chances are that if the screen was hit hard enough, at least one of the CCFL bulbs for the backlight broke too. This created a fault in the inverter circuit, cauing a shutdown after a second or two.
Nov 25, 2011 | Televison & Video
Hi i have MAXENT TV 50" plasma im loking for dish network remonte code to program on it please help
We show no codes listed for Maxent televisions. The best method for programming this remote is called a Power Scan, the steps are below:
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
May 08, 2011 | Maxent MX-50X1 50 in. Plasma Television
I have an 52 inch lg5000 tv . it supposed to be full hd. i ve tried to connect my play station 3 via hdmi cable but the only thing i get is the no signal sigh on the screen i ve tried everything . is my tv...
plug the ps in with power cable only no hdmi. When turning on Hold down the power button until you hear a second set of beeps you have now reset the video settings. Turn the console off and plug in your hdmi and switch back on it should now work.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Panasonic plasma tv doesn't turn on, red light flickers twice
hi look for any swollen capacitors, also plasma's do suffer from poor solder joints on the power board, so check for any rings around the solder pads, test the voltages on the white connectors with a meter the voltages will be written along the connector,thanks
shaun
Mar 01, 2017 | Panasonic Viera TH-50PZ85U Plasma TV
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
Picture gets hung
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Fujitsu P42VHA30WS Television
Relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Mar 22, 2008 | Samsung SPN4235 42 in. Plasma HDTV
PLASMA 50IN TV
hi there your problem is cause by the low side a ass.y board is faulty.hope this help
tony.
Oct 29, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Televison & Video Logo
293 people viewed this question
Top Televison & Video Experts
