Question about Belkin Computers & Internet
Belkin f6b 750 avr circuit breaker button will not engage all backup and one surge protected outlets not working
3 Suggested Answers
  • 150 Answers
SOURCE: belkin f6c750-avr repair / Testing
You could be correct on the transformer. I'm kinda leaning towards a bad cell in the battery. Sounds like it will need replacing.
Posted on Sep 03, 2009
puertobori
  • 7733 Answers
SOURCE: For a Belkin F6C550-AVR: (1) House
Belkin : Support : Setup Assistant for Routers
Posted on Oct 25, 2010
Not working when plugged
Most UPS's have split power. One is for Surge protected which is probably the half still working. The other come from a switching device called a relay. The relay is on the circuit board inside. If the battery backup'd half is dead, then that relaying is not connecting the power source to the three outlets. It could be due to a defective control circuit or the relay is bad. If you dont know electronics, either buy a whole new unit, or send it in for a rebuild with a place that knows what they doing. The manufacturers approved service places charge a reasonable price, but wont tell you anything for DIYers. I found a place in western canada that services them and does correspond with tips...that worked. And the obvious warning, the insides of a UPS can kill you if you dont take proper precautions
Jan 09, 2014 | APC Computers & Internet
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Plug it in and nothing happens. no lights or noise. The two surge protection outlets draw power, the other six don't.
    Unplug the surge protector (and all units plugged into it) and take it apart - you'll see how the outlets are connected to provide a closed circuit when on. Make sure all connections are secure and carefully put the unit back together.
    You should be able to use all units plugged into it.
    Please let me know if you need further assistance.
    carsandcomps,
    Guru, Premium Expert @ Fixya.com
    Oct 02, 2010 | Belkin PureAV Home Theater Battery Backup...
    Conext 900 AVR. Won't turn on, no lights. Power still out of the surge protected outlets, but no power out of the battery protected outlets. Opened it up, don't see anything damaged, using a meter checked...
    I had the same model/symptoms (no lights on the front panel). I had a compatible, though smaller, battery from a Verizon Fios backup unit, and I tried that in the UPS--it worked. That confirmed that I just needed a new battery.
    Feb 03, 2010 | APC Conext 900VA (cnb900) UPS System
    Cripes, been working great for several years, (My Harman Kardon AVR 335) but my coffee maker shorted out and trip the circuit breaker in my house that must also be in line with living room. Of course I...
    Sounds like it's in protection mode, receivers do this so avoid circuit damage. It's usually only when speaker connections are shorted, but here it appears it has a surge protection of some kind. A local hifi shop will usually be able to reset such problems.
    Jan 05, 2010 | Harman Kardon AVR 335 Receiver
    Belkin f6h-350-usb-dl no power out in the upper row
    One set of outlets is surge protect and one row is battery backup. When you have a bad battery that row will not work. Remove the battery and test it.
    Dec 13, 2009 | Belkin (F6H350-USB) UPS System
    Belkin f6c750-avr repair / Testing
    Sep 03, 2009 | Belkin (F6C750-AVR) (BELF6C750AVR) UPS...
    UPS issues with bad power
    First, most of the UPS sensitivity can be adjusted. Setting a higher sensitivity will make the UPS compensable much faster if the current goes to high to too low thus always providing a good power quality to the equipments. For example, on a BackUPS RS the low level can be configured from 94V to 104V and the high level from 126V to 136V. An entry-level UPS such as the APC BackUPS ES will switch to battery mode as soon as the power goes out of the sensitivity range. On the other hand, a high-end UPS for workstation like the APC BackUPS RS has a feature called Automatic Voltage Regulation (AVR) that compensate at some extent without requiring the battery; this makes the battery last longer before needing to be replaced.
    Second, most of the UPS have "Battery Protected" and "Surge only" outlets. Make sure that the computers are connected to the "Battery Protected". The "Surge only" outlets will only protect from parasites or surges like a thunder storm. They should be used for less important stuff like a desk lamp or devices with high demand peek such as a laser printer.
    Third, the use of a power bar connected to the "Battery Protected" side should not have any impact as long as it is not overloading the UPS. Personnaly, I have a power bar connected to both my UPS.
    Feb 06, 2008 | APC Smart-UPS UPS System
    Computers & Internet Logo
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
