Cars & Trucks Logo
Posted on Apr 03, 2011
My subaru's engine temp rise's quite alot when driving through towns, doing alot of stopping and starting, but when i'm constantly moving the engine temp drops to normal,, is that a major problem?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Apr 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
1900
Points
30
Check your fan belt, water thermostat, radiator, water, oil,. The best one is to overhaul your radiator or replace new one.
How do i change my auto tranny oil on 1991 subaru
THere is a dran plug on the left side of the tranmission oil pan. These transmission hold alot of oil and it could be very hot, so be careful. You need to change the filter too and these are quite expensive. When re-filling
I Use care not to exceed the upper limit level.
I ATF level varies with temperature. Remember
that the addition of fluid to the upper limit
mark when the transmission is cold will result
in the overfilling of fluid.
4) Fluid temperature rising speed
I By idling the engine
Time for temperature rise to 60°C (140°F) with
atmospheric temperature of 0°C (32°F): More than
25 minutes
<Reference>
Time for temperature rise to 30°C (86°F) with
atmospheric temperature of 0°C (32°F): Approx. 8
minutes
I By running the vehicle
10 minutes
5) Method for checking fluid level upon delivery or
at periodic inspection
Check fluid level after a warm-up run of approx. 10
minutes. During the warm-up period, the automatic
transmission functions can also be checked.
From my Subaru TSB's
2answers
Fluctuating hot water gauge for Subaru Baja
check your coolant level, its may be low causing the fluctuatiion also the loss of heat. if its ok replace your thermostat its not regulating tempature right
After driving for about 4-6 hours the temp rises
You should have your a/c system ck'd. Reason could be excessive system pressure and temp. This would explain the a/c safety turning off the a/c and the temp rise of the engine cooling system. Good Luck.
1helpful
1996 Subaru Legacy overheating in strange way
Was the water pump brand new or rebuilt? I have seen rebuilts fail on the first test drive.
Before pulling the head, I would take it to a shop and request a CO2 test to check for combustion gasses in the cooling system. Shouldn't cost more than $30 and is a pretty definative test.
I have a 98 Subaru outback legacy with 151,000 miles. I've had it for roughly 5 months in which time I had the head gasket, radiator, and rear main seal replaced. I live in MN, after the last round of...
I would make sure the Termostat u instaled is correct. Also have the Coolant system flushed and replaced. The gauge may not be reading properly which could be the sending unit. You have already replaced the main components that fail. Hope this helps and have a great day.
2002 gmc van overheatig
It has a leak. Fill up the radiator and the coolant tank. Then restart it and check for leaks.
Top Subaru Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Subaru Expert? Answer questions, earn points and help others
