Question about Husqvarna Garden
My 359 etech will start running bad after cuting one or two sticks of wood then die. If it sets until the next day It will again start. It has a good blue spark even when it won't run. It won't even fire on ether or puting gas in the spark plug hole.
  • Husqvarna Master
  • 2,239 Answers
If it still has a good spark it must be a fuel issue, replace the filter in the fuel tank check the fuel hose up to the carb for cracks or splits, if this does not help the next step is to service the carb, let me know if you need help with this.
Posted on Apr 04, 2011
I have a 2000 ford windstar that I bought last monday, it died last tuesday. go figure. I was driving down the road and it just died with no warning at all just stopped. I had it towed then the next day go...
You have O2 Sensor Codes
I believe you have a bad fuel pump,
thus low pressure and the O2 Sensors,
set a lean fault code
Check fuel pressure at the rail when you turn
the key to start or it is running
Changing spark plugs is something that
never has to be done to find out what issues
you have.
You could throw away a couple and it should start
Also NO Parts EVER get Changed until
TESTED and found to be bad
Mar 09, 2011 | 2000 Ford Windstar
How do i just get it to b set at the same time every day on and off just leave it on one setting is that how?
You posted under a timer sold with several brand names:
Open following link to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
manual
http://waterheatertimer.org/pdf/Woods-59377.pdf
As you know, the manual is longer than space allowed for free answers.
Open the manual.
Plug timer in for 1 hour to charge internal battery.
Unplug timer to program.
Manual gives steps for setting current time. So if clock on your wall says 9:42 pm, set timer for 9:42 pm.
Next you begin programming.
Manual says press PROG button until display shows 1 and on
This is program1 on.
Set the hour, minute, using Hour and MIN buttons for program1 on.
Press day button to select days.
In your case, keep pressing Day button until all days of week display.
For example Mo TU We Th Fr Sa Su would be all days of week.
Next you press PROG button until display shows 1 and off
This is program1 off
Set hour, minute, and day you want for program1 off.
Again you would press Day button until all days display.
After setting program1 on and off times, press Prog button again to validate choice, then press clock button. You do not have to set more programs.
Timer also has random and countdown functions explained in manual, do not use these unless you want.
If manual is confusing, write down the steps, or add a comment.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 02, 2011 | Woods Industries 59377 Indoor Digital...
I have model 0155671 but it doesnt look like the model online mine has four buttons across set time plus minus next riw is rnd ctd bottom is manual i dont understand when it says select 12 or 24...
A) 12-24 hour choice >> just use the 24 hour display.
That gives you day and night hours
I don't know why these companies offer 12hr-24hr option on timers.
B) Military time vs Regular time (military time does not use am and pm)
1 1am
2 2am
7 7am
11 11am
12 12noon
13 1pm
14 2pm
20 8pm
23 11pm
24 12midnight
C) Utilitec 0155671 is same as Woods 59377
Before Woods made 59377, they made 49566 (which is also called TD1101 and TD1300)
I think you have Woods 49566
Manual for Woods 49566:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
Add a comment at any time.
D) How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
1) Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
2) Program review:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
3) Program the timer:
ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not hold set button down as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you will set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
4) Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
Dec 05, 2010 | Hardware & Accessories
How to program #49556 te158wta my add: gd659@cgocable.ca
Woods 49556 / TD1300 manual
Set current time.
Release SET button.
Release SET button.
Release SET button.
Programing overview:
Program the timer:
Set ON
Press SET button, but do not press and hold set button as you did when setting current time.
program1 ON is set, next you must set program1 OFF
OFF
Last step:
Dec 04, 2010 | Woods Hardware & Accessories
It starts and runs if i use the pedal i could drive it all day long but it will not set there and idle and it will die if you dont pedal it i replaced the fuel pump and got pressure after it dies it will...
Check for sticking EGR valve. These units bad for valve gumming
up and sticking open creating a vacuum leak. Engine will cut off at
idle. Simple solution, remove valve and clean with choke cleaner spray. Allow to air dry before reinstalling. You can check the valve
with engine running by using a hand held vacuum pump. Let engine cool down before removing, valve in a tight spot under throttle
body on intake
Sep 07, 2010 | 1993 Chevrolet S-10 Blazer
1992 cavalier. starts and drives fine, but will die after it's been driven if i try to put it in gear again. What's the problem? bought it site unseen, drove it home about 7 miles and it started sputtering...
Try pulling the vacuum line off of the EGR valve when the engine is warm and starts to sputter. If it runs good cold and then dies when warm and won't start again until the engine cools it is most likely a bad or sticking EGR valve. Try the procedure to confirm it is the EGR. You can check the internet for location and an image of the EGR valve for your specific car. Please rate me on this answer.
Aug 01, 2010 | 1992 Chevrolet Cavalier
1994 sonoma stops running when it warms up
Replace you fuel Injector pump and check for any bad or clogged injectors. make sure idle adjustment screw is properly set 1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Apr 24, 2009 | 1992 GMC Sonoma
'93 Grand Cherokee intermittently starts and runs
Hi, I had simmilar problem with my 1993 JGC . I ran out of gas and it would not start until the next day. Then it will start and run until I put the brakes on tho stop and then it will die. It starts right back up. Ended up being the voltage regulator in the ECC/ECM. It is at the mechanics shop right now waiting for the ECC to come in.I will post a follow up.
have Fun,
David C
Oct 15, 2008 | 1993 Jeep Grand Cherokee
Garden Logo
97 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
