Question about Mtd Garden
I have a MTD 13AH660F000 that will not turn over. My wife was using it and switched to reverse with the blades engaged and it died as it supposed to, but since then it will not turn over at all. I have a brand new battery in it adn even tried jumping it, but still no power. Is there a safety switch or something that has been tripped? The 20amp fuse is fine, but I replaced it anyway. Any help would be appreciated.
  • 608 Answers
Did you disengage the blades,put it back in neutral and re apply the brake to try restarting?
Posted on Apr 11, 2011
Why does my MTD tractor screech and die when I engage the blade?
Sounds as if the valves need adjusting... You will need a feeler gauge and find out what the specs are for that engines valves clearance...
Oct 11, 2015 | Mtd Garden
Why won't the blades engage on my riding mower 54" mtd 13ap625k730?
You have probably thrown the belt for the blades. If it continues to throw the bet check the tensioner.
Aug 10, 2014 | Mtd Garden
MTD stops running when trying to engage the blades
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Jun 01, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
07 mtd yardsman mower with 13.5 tecumseh runs great untill engage mower , then dies down and blows black smoke
This sounds like a micro switch acting up, the first switch to check is the seat switch, make sure the block connecter is pushed fully home on the switch ( there is often a fail safe inside the connecter should the block come away from the switch )
Jul 08, 2012 | Garden
Runs but when u engadge the blades it dies
I would try bypassing the safety switch on the mower at the bottom of the blade control stick. It's meant to prevent starting the motor with the blades engaged but it or another safety switch can be bad. You may have one for reverse, the seat and brake.
Jul 28, 2010 | Yard Machines MTD Gold 20 HP Lawn Tractor...
My craftsman mower shuts off every time the blades are engaged. What is the problem?
you most likely have a shorted or open safety switch. you did not mention year or model # so I can only guess what configuration you have, but typically there are the following safety switches on a riding lawn mower: clutch/brake on switch (under floorboard at clutch, this allows you to get off the tractor with engine running if brake is applied), Reverse gear safety switch (will shut engine off if attempting to go in reverse with blades on...follow the gear handle rod down to transmission, may be internal or external of differential), there is also usually a disable switch to allow blade operation in Reverse and this is usually relay operated via a button or turn of the key position, Seat safety switch (under seat and usually is disabled via engaging the clutch/brake switch, this switch will kill the motor if you come off of the seat unless brake is applied), and of course a switch that is tied in to tell when blades are engaged (engage handle or PTO switch). It is actually simpler than it sounds and you dont' need to be an electrician to figure it out. start out with a visual inspection of the switches that you can see. I would suspect the transmission position (reverse) switch first, do you have an override? if so, turn it on and see if engine stays running with blades engaged. hope this helps and here is a link to a company that deals mower parts and has alot of great parts breakdown illustrations online. A craftsman is pretty much the same as a MTD or White Outdoor model, so look those up and it will show you the areas where switches are.
http://www.superxpower.com/pages/parts/viewbybrand/55/HusqvarnaPowerEquipment.aspx
Apr 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Blades run in reverse and only for a short distance going forward
ok when was the last time you had the hydrolic fluid changed ?
or the oil for that mater ?
oil breaks down
you wouldnt cook your french fries in year old oil but you will cook your tranny with it in a cub or mtd machine 100-120 hours max for the fluids in an mtd b4 they start to loose texture or viscosity ( sound it out)
hydro pumps di die mtd has 1 monster that is quite expensive also have you changed the filter on the rear axcel lately or is it full of nut butter and in bypass mode
100 hours doesnt seam like much but for a tractor it is
service service service
Jul 25, 2009 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
102 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
