Question about Dacor Preference PGR30SS Gas Kitchen Range
Dacor pgr30 new control board installed, it worked 1 time and quit. clock and timer work but oven will not heat
frankgant
  • 250 Answers
SOURCE: F6 Error
I contacted Dacor and they stated that the F6 error means the ERC or Electronic Relay Control is bad. This part would need to be relaced. They gave me a parts company to contact for the part. It is Appliance Parts Depot at 1-800-642-6420.
Posted on Jul 09, 2008
SOURCE: Kenmore oven stopped working and clock/timer is dead
Try and knock off the oven , leave it for about 10-20 minutes then turn it back on , if its still the same go to the manufacturer or where you bought it... Hope i helped
Posted on Dec 30, 2008
vanni7
  • 163 Answers
SOURCE: Does the Dacor rsd30 have an internal circuit breaker?
Hi!!!you seem to have a problem with your hi- limit switches show here they are resetable in dacor products..just press the top of the hi-limit swith and you will be fine'' they are show here.Good luck
Posted on Jan 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Posted on Mar 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Dacor wall oven
Your tech is making it easy on himself, either he makes bank on the 1300 dollar repair or you back-out and let him off the hook.... Heat/ Temp sensors are nearly universal, so just about any RTD sensor will work in the oven, they are easily replaceable as well. Second, the logic control module is $269.40 at RepairClinic, I would start there- while installing the logic board, pull out the relay board and give it a close look in the daylight to see if any of the solder joints on the back of the board are cracking, burned, or otherwise failing- it is probably fine. Install the logic board and observe operation, the rest of those parts are likely not necessary- your tech sounds like a "Parts Changer Monkey," the old PCM.
Apr 12, 2016 | Dacor EO130SCH Epicure Discovery Wall Oven...
I try to set the clock on the oven but pressing the CLOCK touch pad or the TIME-TEMP pad has no affect. It is completely nonresponsive.
It sound like the board is faulty, its quite common after power surges can cause damage to small circuit boards like clocks, I would recommend changing it as the clock will also provide timing for switch on at a set time cook for time as well.
http://dacor.com/Search.aspx?query=ECS227 Epicure Electric
Hope this is helpful
Regards
John
Oct 31, 2014 | Dacor ECS227 Epicure Electric Double Oven
I've shorted out my oven after attemtping to change the light bulb.
most ovens will not operate until you set the clock - doesnt matter what you set it to as long as it isnt 00:00
Nov 30, 2013 | Dacor Preference RSD30 Gas Kitchen Range
Is the hot surface ignitor supposed to stay on all the time on my PGR30SS? My oven takes a long time to heat up.
( yes) most ovens that use hot surface system stay on during heating . if its weak is orange glow instead of white hot . this would cause slow heat up / hope this helped ****
Dec 04, 2009 | Dacor Preference PGR30 Gas Kitchen Range
Dacor PGR 30 oven does not heat
I have had the same miserable experience - replacing the brain, touchpad, expensive parts - for this supposedly high-end appliance.
Have you checked the ignitor bar? See a good explanation of that at http://www.ignitors.com/oven-ignitors/
and also http://www.theignitorstore.com/product/frigidaire_oven_range_igniter_5303935066/range_oven_igniters
Nov 23, 2009 | Dacor Preference PGR30 Gas Kitchen Range
F6 Error
ok.. don't you any schematic manual in there...?
Jul 09, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor oven
I believe it is supposed to be. Prebake, including the convection fan, will happen until the oven reaches the set temperature.
Dec 11, 2007 | Dacor Preference PGR30 Gas Kitchen Range
Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
ECS130 - Possessed Oven
The fix is replacing the mebrane panel. Recent poster advised they where able to get Dacor to send a new panel and they would install (it's not difficult). I bought one online for around $175 and installed myself. Do a search for details.
May 23, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor Preference PGR30SS Gas Kitchen Range Logo
145 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
