Question about Danby Dishwashers
I recently purchased a danby 18" portable dishwasher. I live in an area with soft water but the warning light still comes on. Do I need to fill the salt container with just water??
    President:
  • 1,462 Answers
If in a soft water area, no need to do anything
Posted on Aug 05, 2008
I need a manual for a Danby Model DDW1899WP-1 portable dishwasher
Danby has the manual for the DDW1899WP-1 on the product information site: https://www.danby.com/en-us/products/kitchen-en-us/ddw1899wp-1/ . Look in the right hand column as you scroll down. The direct link to the Owner's Manual is currently: https://www.danby.com/wp-content/uploads/2016/04/DDW1899WP-1_EFOM_201504212.pdf .
I hope this helps.
Oct 15, 2016 | Danby 18 inch Portable Dishwasher in...
Why won't my portable dishwasher work?
Recommend check door closed and not blocked; sprayer not blocked, dispenser not clogged, door latch locking and latch sensor connected and conducting.
Dec 31, 2014 | Danby "DDW1899WP 18"" Portable Dishwasher...
Danby portable Dishwasher advances from pre-rinse to dry and then beeps continuously and dry light continues to blink. Doesn't proceed, reset or stop cycle. Just continues to blink.
I actually found out (one of) the solution to this by accident. It could be the water source is not providing enough pressure
I purchased a Danby DDW1899W-1 and, using the connector screwed into my utility sink in the basement, I connected the water. When I tried to run a cycle, I had the same results (filled/emptied 4-5 times, beeped and went to dry cycle).
My alternate, long term plan was to put a Y-splitter (with shutoffs) on the hot water line for my washer, and have one hose go to the dishwasher when needed. I purchased a washer line hose from Home Depot and a 3/4" to Quick Connect fitting from Ace Hardware and then connected the dishwasher to this.
And, Voila! Problem solved!!!
To confirm this was the solution, after the first completed cycle, I connected back to the faucet and, once again had the fill/empty/beep/dry problem. Reverting to the split washer water feed, it was able to run the cycles properly (again!!!)
So you may just need a line that will supply more water pressure to the dishwasher.
Good luck and, hopefully, this solves the problem.
MP
Oct 18, 2014 | Danby Dishwashers
Water softener
Marsena, I am at the point where I'm going to call a repairman. I'm very disappointed that I have a brand new appliance, and no means of having this issue handled. This is a great dishwasher otherwise, but I could not recommend it due to this problem.
Apr 13, 2014 | Danby DDW1899WP Portable Dishwasher
Salt water error message when I have a water softener already
I feed Danby dishwasher salt whenever he asks (buy it by the case online). Still produces marginally clean dishes.
Apr 02, 2014 | Danby DDW1899WP Portable Dishwasher
Danby portable dishwasher ddw1899wp starts taking in water and then stops working with pre-rinse light blinking. Please help me on this issue. Any answer would be much appreciated.
If the water level sensor does not electrically shut off when the level needed is reached, the pre-rinse cycle will error out thinking that the level has not been reached. That sensor is a float device and probably needs to be replaced...
Dec 28, 2012 | Danby DDW1899WP Portable Dishwasher
I have a water-softener dispenser in my Danby 1899 W Portable diswasher. I do not know how to fill the dispenser and I cannot run the dishwasher until this is resolved. The user manual provides no...
I couldn't find it either for a long time:
1) Pull out the bottom rack as if you were putting dishes there
2) Look at the bottom of the dishwasher and there will be a white circle (near the upper left side) where you can add the water softener.
I didn't use any for a while and the dishwasher worked great so I'm not sure why you can't run it.
Sep 30, 2010 | Danby DDW1899WP Portable Dishwasher
Water not flowing into Danby 18"
Okay, this might seem crazy, but it worked. I spent the last 2 days trying to contact Danby customer service to no avail, so I came back here to look for solutions. Found two:
(1) Someone said to open the little rubber cover under the front right of the machine...I couldn't find such a cover.
(2) Someone said to pull off the front plastic panel...mine doesn't seem to be removeable.
So! I turned my Danby DDW1805 upside-down (!) to see if I could locate the aforementioned rubber cover, and a bunch of water drained out of the machine. This is what both solutions above said I wanted to happen, so I flipped it back right-side up and hooked it back onto my faucet.
Golden. Works perfectly again.
May 15, 2009 | Danby DDW1805W Designer Series...
Where do you purchase the dishwasher salt from I recently purchased the AEG favourit and am having problems sourcing the salt....(brisbane area in Queensland Australia)
if you are in a soft water area then salt is not needed but is essential in a hard water area. normally available from any supermarket
Jul 10, 2008 | AEG Dishwashers
Dishwashers Logo
604 people viewed this question
Top Danby Dishwashers Experts
Batista Saint
Level 1 Expert
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
