Question about Lexmark E321 Laser Printer
Problem with printer all buttons flashing
Hello I have a Lexmark e321 printer when I turn the power off and turn it back on the ready/data button lights up and stays lit. When I go to print something the button flashes and than 10 seconds later all of the buttons flash.
  • Anonymous Mar 26, 2014
    data button flashing printer locked no buttons work
All lights flashing is an error indication. to learn the problem you'll need a service manaual. The procedure is to hit the Continue button twice - see which lights flash (secondary code) and consult the manual. Then repeat that step and look up the final code (tertiary code) in the manual. This should be the problem.
Posted on Sep 20, 2008
E120n ALL LIGHTS FLASHING
switch off you printer. pull out power cord from source, wait for 5 minutes then plug in back the power cord to the source and switch back ON your printer
Sep 02, 2015 | Lexmark E120n Laser Printer
Hello! I turn on the printer with USB data cable atached to my pc and the Ready led is on. I installed the printer driver from lexmark support site everything beeing ok until now. I try to print from my...
Please try to switch to another usb port or try using a different usb cable. try to unplug and replug the cable and check if the computer was able to detect the printer.
For further assistance please contact Lexmark Technical Support
Aug 06, 2011 | Lexmark E321 Laser Printer
LexMark e321 printer is printing blank pages. I changed out the ink toner, reinstalled the driver from the E321 disk, changed the USB cable and still get 2 blank pages and the LED button by error is...
Try to disconnect all cables from the printer and leave it off for about 30 seconds to clear the print job. Turn the printer back on and check the status lights, error light stop blinking then try connecting the printer back to the computer and try printing again.
For further assitance, please contact Lexmark Technical Support
Jul 20, 2011 | Lexmark E321 Laser Printer
Lexmark C510 LCD shows underlined black boxes - not wrking
Hello you can try the following, try resetting the printer doing the following. Turn the printer off, then press and hold the arrow pointing left, the select button and the go (green) button. Hold down those three buttons at the same time and power the printer back on and wait if you see a message saying Restoring Factory Defaults. When that message appears you can let go the three buttons. If the same problem of the black boxes that flash appears then you might have a problem either with the Operator Panel or Engine Board. About the price that will run you to replace this parts I don't know.
Jan 28, 2010 | Lexmark C510 Laser Printer
Two lights are lit up on the operator panel of my Lexmark E232 printer: a steady blue ready light and a yellow blinking toner cartridge light. Neither the continue or cancel lights are lit up. This...
Sounds like your photocoductor is at lifes end. You can reset it by doing the following
1. Turn the printer off.
2. open the front cover
3. hold down the cancel X button while turning on the power and keep holding down until all lights stop flashing. Then let go of the x button and all lights should start to flash, close the front cover...and it should reset. You may have to turn the printer off and then back on once to be sure it is reset.
Jul 07, 2009 | Lexmark E232 Laser Printer
Printer doesn't respond
open the start menu go to printers and faxes open that find your printer model clear all unprinted jobs then make sure that the printer option is online and ready see if that works for you
good luck
Mar 22, 2009 | Lexmark E321 Laser Printer
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
All available lights on printer are flashing
More or less your printer fuser has gone bad. Replace the fuse. I suggest that when buying a printer you don't with dell 1710N these printers gives a lot a problem. I work with them every day at work.
I suggest that you go with HP.
Oct 09, 2007 | Dell 1710 Laser Printer
Open Questions:
Lexmark E321 Laser Printer Logo
601 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
