Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Our receiver has just started running when tv is not even on, we have had our set up for about 6 weeks this just started happening?
  • DISH Network Expert
  • 246 Answers
Hey jwwhip,my name is Mike Houston of DISH Network and you're receiver is like a computerit has a fan that keeps the equipment cool. If you are having anymore issues withthe receiver such as not playing or missing recordings or anything pleasee-mail me at michael.houston@dishnetwork.com.
Posted on Apr 03, 2011
SOURCE:
Why is this happening to my Craig 13 inch tv Model:
This is a fairly common issue. First remove the batteries from your remote control/s that are capable of operating your tv. Did this stop the issue? If so, you need to replace your batteries, if not, check the remotes for ay stuck buttons or the possibility of them having had any liquid spilled on them since the problem started. If all is still negative, how close do you live to your nearest neighbor? Sometimes people who live in apartments will receive the input of a remote control from a person living next to them. If all else has been checked, and you have ruled any of your neighbors, then I'm afraid to tell you that the electronics which control the channel and volume settings on your tv are in the process of going bad. This is most likely caused by a small capacitor, but once the capacitor has gone, it can cause even more components to receive incorrect voltages and in turn ruin them causing cascade electronic failure. A repair shop can fix or replace the components or the board, But cost wise, it is rarely worth doing so.
Jul 23, 2014 | Craig Electronics CLC503 13.3-Inch 120Hz...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 11, 2009 | Honeywell Programmable Thermostat Heater
Yamaha rx-v1500 no surround sound
Do you have the owners manual of this Receiver. If yes, then I can guide you the page numbers:
The memory backup circuits prevent the stored data from being lost even if the unit is set in the standby mode, the power cord is disconnected from the AC outlet, or the power supply is temporarily cut. However, if the power cut is more that one week , the parameter values will retun to the factory setting. If this happens, edit the parametets again.
Now you want to reset all parameters:
Use PARAM.INI ( see page 63)
First put the MEMORY GUARD to OFF position.
To go to the the above :
Make sure the OSD is displayed.
Set AMP/SOURCE/TV to AMP,
then press MENU to enter SET MENU
Reach Option mode/2
enter C) PARAM.INI
All the parameters where changes have been made from their original setting would be marked in Asterisk(*).
Make the changes required.
Hope this works for you.
Please do rate this solution and thanks for using FixYa!
Mar 04, 2009 | Yamaha RX-V1500 Receiver
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
I have to unplug the TV occasionally to get the picture to come on at start up.
I have same problem on Sharp Aquos LCD.  I unplug/turn off circuit and then turn back on and it works.  Otherwise no picture, just a light and light goes off.
Jun 27, 2008 | Televison & Video
Loss of channels
If you mean "losing" as in you could no longer tune to those channels because they disappeared out of the channel list entirely, then it's likely a software problem.  If you haven't already, try resetting your DVR to factory settings (since this unit is TiVo powered, it should be under the main menu, Messages and Settings, then Restart or Reset system; follow the on-screen instructions to reset the system).
If you mean "losing" as in you can tune to the channel but there's no signal, then that sounds like a tuner problem to me.  If the box is still under warranty or you lease it, have it repaired or replaced.  If you bought the box and the warranty is up, it looks like you might have to get a new one, or pay for the repair out of pocket.
You might also try calling back to DirecTV tech support and asking to be escalated or to speak with a supervisor; especially if it's a box you're leasing from them, since it is definitely *their* problem in that case.
Oct 21, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Turning volume up on my Denon AVR-485 AMP causes it to turn off
Speaker Impedance:
When speaker systems A and B are used separately, speakers with an impedance of 6 to 16 ohms can be connected for use as front speakers
Be careful when using two pairs of front speakers (A + B) at the same time if their impedance is less than 12 ohms.
The protector circuit may be activated of the set is played for long periods of time at high volumes with an impedance lower than specified are connected.
Oct 16, 2007 | Denon AVR-485 Receiver
Maxent MX-42HPT51- will not respond!
It's less than a year old, give the manufacturer a call
Oct 07, 2007 | Televison & Video
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
93 people viewed this question
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
